Two IP addresses
- Business
- Two IP addresses
Two IP addresses
18-09-2008 2:06 PM
Hi
Is it possible to have 2 static ip addresses on the business package?
If so, what is the cost?
James
James
Message 1 of 3
(3,223 Views)
2 REPLIES 2
Re: Two IP addresses
18-09-2008 2:11 PM
Hiya,
There's no additional cost, but you would need to fill in a RIPE form.
http://usertools.plus.net/ripe/
You'll then need to raise a ticket.
Message 2 of 3
(496 Views)
18-09-2008 3:04 PM
You do James?
No RIPE form is needed for 2 IP addresses.
We can supply IPs in singles, 4 blocks, 8 blocks and 16 blocks. 8 and 16 require the RIPE form and 4 a full explanation behind the requirement for them.
Any block of IPs will see 2 IPs reserved for networking reasons (network address and broadcast). The 2nd in the block will be assigned to your router.
From a block of 4, this means 1 to assign to an internal device, 5 to internal devices on a 8 block and 13 to internal devices on a 16 block.
Requesting an IP block will result in a new set of IPs, we cannot retain or provide the block in addition to your existing IP.
Message 3 of 3
(496 Views)
