TT to Plusnet all done and working
- Business
- TT to Plusnet all done and working
10-08-2018 10:16 AM - edited 10-08-2018 12:15 PM
Well good to report the first part on my line move has gone just fine
17070 now gives my old TT number but it is now on the Openreach network
So well done for part 1
I will see how the FTTC move has gone after lunch
FTTC was on just a few mins ago
All good logged in 1st time no probs
initial line stats
DSLAM type / SW version: BDCM:0xa48c (164.140) / v0xa48c
Modem/router firmware: AnnexA version - A2pv6C038m.d24j
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 0 hour 3 min 21 sec
Resyncs: 0 (since 10 Aug 2018 12:02:00)
Downstream Upstream
Line attenuation (dB): 23.8 0.0
Signal attenuation (dB): Not monitored
Connection speed (kbps): 35236 6874
SNR margin (dB): 6.2 5.9
Power (dBm): 11.7 2.8
Interleave depth: 689 1
INP: 3.00 0
G.INP: Not enabled Not enabled
Vectoring status: 5 (VECT_UNCONFIGURED)
So well done and a big thank you to all of you at Plusnet and the other members who made it happen
Re: TT to Plusnet all done and working
10-08-2018 2:53 PM
Hi @David661.
Glad to hear it's all going well. I've sent you a response via https://www.plus.net/wizard/?p=view_question&id=179601350 .
Thanks - Tahir
16-08-2018 10:11 AM - edited 16-08-2018 10:12 AM
Well here we are one week from moving to Plusnet business from Talk Talk Business
How has it been - The line now syncs FASTER than it did before the move
TT = Bearer: 0, Upstream rate = 6854 Kbps, Downstream rate = 41024 Kbps
PS = Bearer: 0, Upstream rate = 6809 Kbps, Downstream rate = 44980 Kbps
It might not sound much but on a line 700+m from the BT line box every little helps
So much for the TT mantra "the speed is down to Openreach nothing to do with us"
No mention in the TT mantra of the slower NGA profile TT choose to use though (good for a back door speed throttle though)
16-08-2018 1:58 PM
Hi @David661,
Thank you very much for getting back in touch. I'm glad to hear that everything went well with your switch and that your speeds have improved from what they were with your previous provider.
- Business
