Static IP
Stigfish
Static IP
Can anyone tell me how to activate this on my business account please, I've tried the add ons section and the broadband section but find no option. cheers.
9 REPLIES 9
Legend
Fixes: 219
Re: Static IP
So far as I know, and I'm only speaking from knowledge picked up over many years, a static IP is automatically applied on Business accounts - you should not have to activate it, which is probably why you can't find an option to do so.
Stigfish
Re: Static IP
Ahh thank you John, to be honest I never even thought to check if it’s already static haha. I’ll have a look. Thanks again.
Fixes: 1,577
Re: Static IP
Thanks for your post @Stigfish
Static IPs aren't automatically enabled for business accounts, but I've added one for you now.
If you can reboot your router, you should be on the static.
Legend
Fixes: 219
Re: Static IP
@Stigfish Sorry - I genuinely thought they were.
@Gandalf  Sure I read somewhere that static IPs were enabled by default on Business Accounts - has that changed recently, or was I seeing things? 😉
Stigfish
Re: Static IP
Great thank you @Gandalf
Stigfish
Re: Static IP
Hey no worries @jab1 I appreciate you trying to help
Fixes: 143
Re: Static IP
@jab1
They are automatically AVAILABLE on business accounts, but they need to be activated. However the manage static IP interface on the portal does not always appear in user account settings.
Fixes: 1,577
Re: Static IP
@jab1 wrote:
@Gandalf  Sure I read somewhere that static IPs were enabled by default on Business Accounts - has that changed recently, or was I seeing things? ‌‌
As far as I'm aware, they haven't been automatically available on business accounts for the time I've worked here, but I could be wrong or you may have been thinking of a time long ago before time itself when the internet was young.
@Townman wrote:
@jab1 They are automatically AVAILABLE on business accounts, but they need to be activated. However the manage static IP interface on the portal does not always appear in user account settings.
Not automatically. I had to manually add a static IP component and activate it. It's free though for a business account.
No problem, let me know if there's anything else you'd need help with.
Legend
Fixes: 219
Re: Static IP
@Townman , @Gandalf  Thanks both for adding to my knowledge - might never use it, but appreciated anyway.😀
