Some web sites not loading
- Business
- Re: Some web sites not loading
22-05-2014 10:20 AM
Hi guys, I'm after a bit of help.
I've replaced the TG852 router with our Sonicwall, and it connects over PPPOE fine, and our three VPN's are working ok to this office.
However, when someone at the remote office browses the web, sometimes site are either slow to load, or just won't load and IE is telling me waiting for the site to respond.
Three examples are speedtest.net, dorsetecho.co.uk, and unfortunately our own site, canford.co.uk
I've left the Sonicwall's connection to auto assign IP (as it's static from plusnet) Clients get their DHCP from the Sonicwall, are assigned DNS IP's of our Domain Controller, which than has forwarders set to PlusNet's DNS.
NSLookups are all fine and seem to be quick.
When I do a tracert to some problematic sites I get;
C:\Users\Administrator.CANFORD_GROUP>tracert www.dorsetecho.co.uk
Tracing route to m6-lb.newsquestdigital.co.uk [62.233.114.118]
over a maximum of 30 hops:
1 16 ms 17 ms 17 ms lo0-central10.pcl-ag01.plus.net [195.166.128.182]
2 16 ms 16 ms 16 ms link-b-central10.pcl-gw02.plus.net [212.159.2.162]
3 15 ms 15 ms 15 ms xe-10-0-0.pcl-cr02.plus.net [212.159.0.194]
4 16 ms 16 ms 16 ms ae2.pcl-cr01.plus.net [195.166.129.6]
5 15 ms 15 ms 15 ms ae1.ptw-cr01.plus.net [195.166.129.0]
6 * * * Request timed out.
7 25 ms 26 ms 25 ms no-ptr.as20860.net [62.233.127.242]
8 26 ms 26 ms 26 ms no-ptr.as20860.net [62.233.118.230]
9 29 ms 25 ms 25 ms no-ptr.as20860.net [62.233.127.246]
10 25 ms 25 ms 59 ms no-ptr.as20860.net [62.233.118.221]
11 26 ms 25 ms 25 ms 62.128.192.197
12 25 ms 25 ms 24 ms 62.128.192.194
13 25 ms 25 ms 25 ms no-ptr.as20860.net [62.233.127.178]
14 28 ms 27 ms 31 ms m6-lb.newsquest.co.uk [62.233.114.118]
Trace complete.
C:\Users\Administrator.CANFORD_GROUP>tracert www.canford.co.uk
Tracing route to www.canford.co.uk [195.97.254.131]
1 72 ms 23 ms 23 ms lo0-central10.pcl-ag01.plus.net [195.166.128.182]
2 16 ms 16 ms 16 ms link-a-central10.pcl-gw01.plus.net [212.159.2.160]
3 15 ms 15 ms 15 ms xe-10-0-0.pcl-cr01.plus.net [212.159.0.192]
4 16 ms 15 ms 16 ms ae1.ptw-cr01.plus.net [195.166.129.0]
5 15 ms 16 ms 15 ms ae2.ptw-cr02.plus.net [195.166.129.5]
7 25 ms 25 ms 24 ms ge0-1.thlon-cr01.onyx.net [194.176.73.18]
8 24 ms 24 ms 25 ms ge0-3.dbncl-cr01.onyx.net [195.97.199.2]
9 24 ms 24 ms 24 ms ge0-3.dbncl-er05.onyx.net [194.176.72.60]
10 ^C
(Cancelled the tracert as our server doesn't reply to pings).
Anyone any ideas?
Carl
Trace complete.
10 ^C
Anyone any ideas?
Carl
Message 1 of 5
(2,015 Views)
4 REPLIES 4
22-05-2014 4:54 PM
Hi Carl,
Out of interest, do you get the same issue with the TG582n?
Message 2 of 5
(687 Views)
23-05-2014 9:44 AM
Didn't 'notice' any issue when it was tried with an ipad and the TG582. I think I may have to get someone to put the TG582 back in and test it with a wired laptop.
Unfortunately it means rejigging my VPN's, and other settings again changing everything back to Onyx for a while.
Can I use PlusNet's DNS if I'm not connected to it? Saves having to change my Domain Controllers again too.
Message 3 of 5
(687 Views)
23-05-2014 5:00 PM
Quote from: Griff Can I use PlusNet's DNS if I'm not connected to it? Saves having to change my Domain Controllers again too.
Connected to what? The 582n? You can use pretty much any router of your choosing with our DNS servers. You need to be connected to a Plusnet broadband line in order to query them though.
Message 4 of 5
(687 Views)
27-05-2014 9:38 AM
Bob, I was referring to using Plusnet's DNS server if I was sending my traffic down my Onyx internet line. I was going to revert back to my Onyx line, and to save time leave my servers DNS set to Plusnet
I think I may have solved the issue. My Sonicwall PPPOE connection had it's MTU setting at 1500 (default). I reduced that to 1492, and the sites I was having problems with seemed to be all loading fine now, and fairly quickly too.
The tracert still timeout at the same hop, but I'll keep an eye on it and see if that's all it was.
Quote The maximum transmission unit, here on referred to as MTU, is the maximum amount of bytes that can be encapsulated in an IP packet. The MTU size includes the data payload, any transport headers (such as TCP, UDP, GRE, RTP, or ICMP), and the IP header.
It is generally recommended that the MTU for a WAN interface connected to a PPPoE DSL network be 1492. In fact, with auto MTU discovery, 1492 is discovered to be the maximum allowed MTU. However, having an MTU of 1452 is most optimal.
The maximum MTU for Ethernet connections on SonicWALL devices is 1500 bytes (Ethernet maximum MTU size). Having an MTU of 1500 allows for 1460 bytes of data payload, 20 bytes of TCP header, and 20 bytes of IP header. With PPPoE connections, the PPP and PPPoE header increases the frame size by 8 bytes, so we must lower the MTU to 1492.
Message 5 of 5
(687 Views)
- Business
