Query about Actinic ecommerce systems running on PlusNet
- Business
- Query about Actinic ecommerce systems running on P...
20-08-2009 6:44 PM
I'm planning to develop an ecommerce site using Actinic (probably the Express version to start) and hosting it on PlusNet. Does anyone already do this and have any comments/rants/suggestions?
Message 1 of 5
(1,973 Views)
4 REPLIES 4
Re: Query about Actinic ecommerce systems running on PlusNet
21-08-2009 1:36 PM
My understanding of Actnic Express is that they host it and you point your website to it. From their FAQ
Actinic Express automatically provides you with a unique shop address to access your store directly. This will be in the form of:
http://shop1.actinicexpress.co.uk/shops/myonlinestore
(where myonlinestore is the name you give to your store)
Simply add a new link on your existing website with your shop address and customers will be able to click directly through to your store.
I dont believe you can actually host the Express version on your Plusnet webspace if I'm reading that info correctly.
Message 2 of 5
(207 Views)
01-09-2009 6:39 PM
Thanks, Mark -- you're quite right, and I've started to build my shop already. I have a domain registered with PlusNet which I want to use for my shop, and Actinic have given me the IPv4 address to point it to. I've added a DNS type A record for this domain using the page in my member area here, but when I try it I'm still being sent to my PlusNet website. Is it just a matter of being patient or do I have to do anything else?
Message 3 of 5
(207 Views)
02-09-2009 8:27 AM
I've just tried 2 of your domains (the two which are similar) and I hit the Actinic default page with both albeit with a notice stating
So it would seem that you've pointed it correctly but still have to configure the shop.
Are you perhaps seeing a cached page when trying to hit that domain?
Quote Store could not be found
If you have just registered for a new Express store you will need to configure your domain name.
To do this log into your merchant control panel at https://secure3.actinicexpress.com/merchant/index.php
Then goto the 'Domain Configuration' section which can be found under the 'Setup Store' menu.
Message 4 of 5
(207 Views)
02-09-2009 5:54 PM
It was a matter of patience and a steep learning curve on DNS record management! It's coming together now - thanks for your help.
Message 5 of 5
(207 Views)
- Business
