PTR Question
- Business
- PTR Question
PTR Question
31-07-2012 4:00 PM
I have a question regarding PTR records.
We have recently switched to PN business broadband and have a static IP, our domain and email are hosted elsewhere and we have an 'A' record pointing to our PN static ip for email delivery.
Now I have been doing some tests and our PN static IP is pointing to xxx.plus.com which can cause potential mail delivery problems.
e.g.
Our mail server is mail.xxx.co.uk and resolves to 1.1.1.1. So 1.1.1.1 resolves to xxx.plus.com
Presumably I need to get it changed so 1.1.1.1 resolves to mail.xxx.co.uk (presumably not 'xxx.co.uk', omitting the 'mail.'?)
Many thanks.
e.g.
Many thanks.
Message 1 of 4
(3,697 Views)
3 REPLIES 3
Re: PTR Question
31-07-2012 4:04 PM
Hi consumerinsight,
This is something that can indeed be done. Please raise a support ticket quoting the IP address (were you have more than one static), that you would like the rDNS updating for this and quote the fully qualified domain name that the PTR record should point to.
This FQDN must point to the IP address already, as we will be unable to facilitate this until DNS points here.
Message 2 of 4
(379 Views)
Re: PTR Question
31-07-2012 4:13 PM
Thank you for the speedy reply!
Can you confirm that the FQDN needs to be mail.xxx.co.uk and not xxx.co.uk?
I have attached a copy of our 'A' record.
Thanks.
Thanks.
Message 3 of 4
(379 Views)
Re: PTR Question
31-07-2012 4:25 PM
Yes,
One limitation is that we cannot use the root of your domain to set this up, so will need mail. or something else subtitle.
Message 4 of 4
(379 Views)
