Outgoing calls barring
rccgohl
How can I bar calls from going out, please?
6 REPLIES 6
maybeicanhelp
Re: Outgoing calls barring
You could try ring and ask if you can be routed directly to Plusnet whenever you use the phone, they use it when you haven't paid your bill. It's worth a shot.
Fixes: 390
Years ago Plusnet offered the service for free, you just had to pay if you wanted it removing, see here :https://community.plus.net/t5/Home-Phone/Call-barring-on-Plusnet/m-p/818783#M7622 . I don't know if it's still available as it's not listed as an available feature in the same way as BT offers it. You can only contact Plusnet and ask or wait and see if a Plusnet staffer comes along and picks up this thread.
Fixes: 143
A warm welcome to the forums.
I take it that you want to stop people using your business line for making calls?  Are you able to simply remove the phone handset?  Lock it up in a cupboard?  Would one of these serve the same purpose - https://www.capella.co.uk/js131-bt-box.html or try researching phone guard products.  I have a Panasonic DECT phone set which can be programmed to bar outgoing calls.
EmilyD
Fixes: 117
Hi @rccgohl,
We're not able to offer outbound call barring I'm afraid. I would recommend taking a look into the suggestions that @Townman has made.
 Emily D
rccgohl
Thanks, Emily.
rccgohl
Thank you, Townman. Would try those suggestions.
