Odd VPN issue
- Business
- Odd VPN issue
Odd VPN issue
24-09-2014 3:39 PM
Hi
We have a another site connecting into our VPN however we keep getting 806 GRE issues
It seems to work fine on other isps no problem - they can dial in with no gre issues
we have IP such 10.81.48.*
They have ip 10.86.* and then go through a connection with lightspeed firewall
We are using Windows Server 2008 r2 and PPTP with PlusNet business and Technicolor TG582n
Message 1 of 4
(1,596 Views)
3 REPLIES 3
Re: Odd VPN issue
06-10-2014 11:09 AM
Any suggestions?
Message 2 of 4
(506 Views)
Re: Odd VPN issue
06-10-2014 5:29 PM
Message 3 of 4
(506 Views)
Re: Odd VPN issue
10-10-2014 9:16 PM
When you say lightspeed firewall, do you mean Lightspeed systems? http://www.lightspeedsystems.com/en-uk/
Is it one of the Rockets or the older TTC?
If it's the rocket it might be worth temporally white-listing the IP of the VPN concentrator to see if it makes a difference, if it is the rocket we're talking about last I saw of them they were more of a web filter than a firewall.
That said I did have one block traffic from a remote managed Wi-Fi AP as p2p traffic before, took me quite a while to figure out what it was as well because with the rocket being a Bridging device I had totally forgotten about it.
Message 4 of 4
(506 Views)
