Need help to transfer out 3 .co.uk domains
thpegg
Please could someone assist me with transferring out the three domains that I have tied to my account.
My understanding is that the existing IPS tag may need to be changed and that I may need an EPP code?
I have managed to track down one of the three under my join email on nominet so I could action that one but the other two aren't showing up so I have no clue what email they were registered under!
8 REPLIES 8
Fixes: 530
Re: Need help to transfer out 3 .co.uk domains
for a .uk domain the current registrar need to change the ipstag to that of the new registrar. No epp code is needed
thpegg
thanks.
hopefully someone will reach out so i can get it arranged.
Fixes: 530
I'm sure one of the Help team will, it just might take a little while
willcutforth
Fixes: 113
Hey there @thpegg I can see you have been in contact with the call centre, is everything sorted now?
 Will Cutforth
Suraklin
Hi Will - this is thpegg (no idea why i can't log in as that anymore but go figure).
I would say it is sort of sorted.
All 3 domains are now registered on my new hosting place. Two of them were done by your team but one I had to do myself via nominet.
One domain has gone from the hosting panel in the domain management page but the other two are still there.
So it looks like there is some clean up work to be done somewhere but at least all my mail is now redirected to my new mail host so that's 90% of the bale.
willcutforth
Fixes: 113
@Suraklin Now you are just trying to confuse me Wink Ah that's a bit of a pain, I have got it removed from there anyway for you Smiley
 Will Cutforth
Suraklin
imagine how confused I am. maybe it's the heat!
Thanks for sorting that I can see that they are gone so hopefully all is now as it should be.
Now I just have to figure out what to do about my phone and broadband!
willcutforth
Fixes: 113
If there is anything remotely distracting I end up as confused as anything, the heat doesn't help either
Glad all is well with it. If you ever figure out what you want to do with the broadband lemme know Smiley
To close let's have a dad joke: My wife said I should do lunges to stay in shape. That would be a big step forward
 Will Cutforth
