My business speeds
- Business
- Re: My business speeds
My business speeds
24-12-2007 5:43 PM
Used to have no problems with my broadband and suddenly my upload went from almost 900 kbps to 320 kbps and no mater how many times I reset my router it keeps synchronizing on 320 sometimes a bit more. Never had that problem.
My download is ok but it's the upload that is important to my as I'm sending loads of data to Poland.
Can't even surf normally as pages are loading for ages.
Can't do a BT speed test aether.
finally managed to get through the BT speed test
IP profile for your line is - 6500 kbps
DSL connection rate: 320 kbps(UP-STREAM) 7616 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 4990 kbps
27-12-2007 3:29 PM
Hope that helps,
05-01-2008 11:57 AM
Moderators note by James_H : Removed full quote of previous post - it is not needed in this situation. : link:rules
05-01-2008 12:34 PM
A bit of a shot in the dark, but have you tried a different filter?
05-01-2008 1:15 PM
05-01-2008 1:42 PM
Quote from: PJ Is that the upstream connection speed reported in your router or the upstream transfer speed from a speed test.
How would the router report a different sync speed to the BT test? I've never seen it!
Quote from: viperone IP profile for your line is - 6500 kbps
05-01-2008 2:22 PM
05-01-2008 2:33 PM
That's not any old speedtester - that's the results from the BT performance tester!
05-01-2008 2:46 PM
05-01-2008 2:53 PM
Quote from: PJ The data transfer speed from a speedtester (such as mybroadbandspeed) is never the same as the sync speed.
Done that broadband speed test and here are the results
THAT DOESN'T LOOK GOOD
ANd again nothing was downloaded or sent through net while the test was done.
05-01-2008 3:01 PM
05-01-2008 3:11 PM
Is there any audible noise on the line you use to receive broadband if you dial 17070 option 2?
This is what my router shows
Downstream Upstream
SNR Margin 7.6 6.0 dB
Line Attenuation 23.4 14.0 dB
Errored Seconds 0 0
Loss of Signal 5 5
Loss of Frame 0 0
CRC Errors 0 0
Data Rate 7616 320 kbps
Latency INTERLEAVED INTERLEAVED
There are no audible noises on the line.
Few posts above you have broadband speed test results.
05-01-2008 3:14 PM
Quote from: jelv One last thing to check - have you plugged the filter and router in to the test socket behind the master socket and checked if that still gives the same sync speeds? If so you need to raise a fault at http://faults.plus.net/ - mka sure you make a point of highlighting the particularly low upload sync.
Done that. Issue is on further investigation.
