Migrated ADSL to Plusnet with upgrade to FTTC - got BT cease charge
- Business
- Migrated ADSL to Plusnet with upgrade to FTTC - go...
06-10-2015 7:06 PM
As the subject says. ADSL broadband (over a BT line) was migrated to Plusnet (who use BT lines) then upgraded to FTTC.
The previous ISP has now invoiced for a BT cease charge of £32+VAT because BT say the line moved from DSL to LLU.
Is the previous ISP trying it on or have BT really charged them a cease charge for a line migration?
I have also raised a ticket 112112508.
Message 1 of 7
(3,901 Views)
6 REPLIES 6
Re: Migrated ADSL to Plusnet with upgrade to FTTC - got BT cease charge
06-10-2015 7:18 PM
I had a similar issue when I moved from BT Fibre to PlusNet, it took me 45 mins on the phone to BT to explain that none of the following points applied to my transfer, they even sent me an email acknowledging that I was moving. This email was the final straw that eventualy convinced them to give me the £30 back. The following is from BT's cease charge page, if BT was not your ISP, look for their terms and conditions:
Broadband Cease Charge
Change is ahead
From September 20th 2015 in certain scenarios when the cease charge applies, as laid out below, customers with fibre optic BT Infinity or Faster Broadband will pay £5.50 and customers on our standard BT Broadband (ADSL) will pay £31. These charges are compensatory and not subject to VAT.
What is the Broadband Cease Charge?
The Broadband Cease Charge is a charge raised in certain circumstances to cover the additional cost to BT of the work required within an exchange to recover equipment and amend records when a Broadband line is ceased.
When will the charge be raised?
This charge will be raised should you :-
1.Switch to a Cable provider (with a different network).
2.Switch to another Broadband provider without following the standard transfer process*.
3.Cease your Broadband completely.
4.Cease your Broadband and move outside of the UK.
When won't the charge be raised?
This charge will not be raised should you :-
1.Move home and you re-connect to BT Total Broadband via the homemover process.
2.Move home and we are unable to provide the service at your new UK address.
3.You are ceasing service due to bereavement or severe illness.
Change is ahead
Message 2 of 7
(1,084 Views)
06-10-2015 7:28 PM
The invoice from the previous ISP just says
"Following your recent broadband migration, we have just received notification that this migrated from DSL to LLU and as such has attracted a cease charge from BT, which we must pass on to you."
Which is nonsense (unless Plusnet are using LLU now).
Message 3 of 7
(1,084 Views)
06-10-2015 7:38 PM
We placed the order as a transfer of both services, the orders were matched and we followed the correct process. I've replied to the ticket with a little more information for you.
Message 4 of 7
(1,084 Views)
06-10-2015 8:45 PM
Many thanks for your prompt responses.
Message 5 of 7
(1,084 Views)
04-01-2016 9:31 AM
Hi Chris.
BT still aren't giving up.
They want a screenshot from ECO...
New ticket 117347321 raised.
Message 6 of 7
(1,084 Views)
27-01-2016 3:53 PM
Hi Chris.
BT are digging their heels in.
BT are upholding the charge as valid - this service was ceased and the cease fee is valid.
It appears Plusnet ceased the line by doing a cease and re-provide, which will unfortunately cease any underlying broadband service. This re-provide also included a simultaneous provide on an FTTC service for the same date, if the broadband had just been migrated then this wouldn't be the case. I believe Plusnet were unable to provide a screenshot from BT Wholesale because this would show a simultaneous provide tied to the line re-provide, rather than a migration from another provider.
I have raised ticket 118877878
As Plusnet are owned by BT, do you have a way to sort this internally?
Our old ISP and ourselves are getting fed up playing piggy in the middle so to speak.
Message 7 of 7
(1,084 Views)
- Business
