Mail Relay
- Business
- Mail Relay
Mail Relay
05-01-2010 9:36 PM
Hiya,
Can someone remind me of the autoturn DNS name for the mail relay MX record. I've just changed my SMTP details and forgot to make a note of it so now no longer have a backup relay.
Message 1 of 6
(2,940 Views)
5 REPLIES 5
Re: Mail Relay
06-01-2010 12:36 AM
I believe it is autoturn.plus.net and you connect on port 79
Message 2 of 6
(987 Views)
Re: Mail Relay
06-01-2010 7:04 AM
Sorry I meant what's the name for the MX record I need to add to my domain's DNS records for mail relay if my mail server goes offline. I presently only have the one record, which is my external IP.
Message 3 of 6
(987 Views)
Re: Mail Relay
06-01-2010 9:19 AM
I thought when you selected SMTP mail delivery for a domain it automatically added the autoturn server. Have you tried changing it to specify your own DNS and then change it back to SMTP?
It's also possible that it won't show up in the DNS maintenance for a domain, but will be there if you check the DNS records using dig or nslookup.
Message 4 of 6
(987 Views)
Re: Mail Relay
07-01-2010 8:13 AM
When I had my SMTP set to use the deault, nslookup showed to MX records:
mail.domainname.co.uk
plusnets mail relay
I had to change it to 'specify DNS records for my domain' and now it only shows 1 MX record:
smtp.domainname.co.uk
I can't remember what the mail relay's MX record is! I could change it back and wait for DNS to populate I suppose!
plusnets mail relay
Message 5 of 6
(987 Views)
Re: Mail Relay
16-01-2010 12:35 PM
Hi
On my domain as the secondary record it is
10 autoturn.plus.net.uk 84.92.1.1
Regards
Mark
Regards
Mark
Message 6 of 6
(987 Views)
