How to use Apple AirPort Extreme WITHOUT using technicolor TG582n Plusnet?
- Business
- How to use Apple AirPort Extreme WITHOUT using tec...
12-04-2014 2:59 PM
Hello, I just got an Apple AirPort Extreme and successfully set up a new WiFi network via technicolor TG582n Plusnet.
Ideally I would like to use WiFi provided from AirPort Extreme WITHOUT technicolor TG582n Plusnet. Is there any procedure to make it possible? I once connected the cable from AirPort Extreme to ADSL Filter, but it did not work.
Many thanks for your support in advance,
Masa
Plusnet Business Broadband (ADSL)
Masa
Message 1 of 5
(2,923 Views)
4 REPLIES 4
Re: How to use Apple AirPort Extreme WITHOUT using technicolor TG582n Plusnet?
12-04-2014 3:14 PM
The Airport Extreme does not have an ADSL modem built in so you'll always need an intermediate device between it and the phone line.
Message 2 of 5
(993 Views)
26-11-2014 3:02 PM
Did you set up your Airport successfully ? I am trying to set one up and whilst I can connect to the web, I get the message "no internet access". There is obviously a setting I am missing
Message 3 of 5
(993 Views)
28-01-2015 12:24 PM
Similar problem here. Got a BT modem (supplied by PlusNet) to connect to my fibre .. This is connected to the Technicolor Router.
I want to replace the Technicolor Router with my Airport extreme, as its 100 time better and can support my music network of Airport express's around the house.
My current attempts to configure the Airport Express to use my PlusNet Login details though PPPoE are failing ... What have I missed!
Christopher
Christopher
Message 4 of 5
(993 Views)
28-01-2015 1:11 PM
Oh god worked out my username was wrong .. All working fine .. And buy what and improvment!!
Message 5 of 5
(993 Views)
- Business
