How long for additional mailbox user password change?
- Business
- Re: How long for additional mailbox user password ...
14-11-2007 9:38 AM
I changed a mailbox password approx 10 minutes ago and am trying to login on Webmail with the usual grimme+username and the new password.
It keeps telling me I've used the wrong username or password - how long should I need to wait before I can use the newly changed password to check e-mail?
Message 1 of 4
(3,670 Views)
3 REPLIES 3
Re: How long for additional mailbox user password change?
14-11-2007 11:24 AM
Apologies for answering my own question, but as I still couldn't login to the webmail account an hour after changing the password, I took a chance and deleted, then recreated the account with the same name and password.
It all seems to be working fine now - all very strange indeed though!
Message 2 of 4
(1,026 Views)
14-11-2007 11:49 AM
Strange, did you try logging in with the previous password during this time?
Message 3 of 4
(1,026 Views)
19-11-2007 10:42 AM
Yes, had tried using both older and newer passwords several times before. Had also tried changing the password again approx 1 hour after the original change.
It was only the removal and re-creation of the mailbox from the portal page that allowed the mail account to be used and all seems to be still working OK, thanks.
Message 4 of 4
(1,026 Views)
- Business
