Find Full DSL Stats for the SNR connection settings
- Business
- Re: Find Full DSL Stats for the SNR connection set...
02-07-2015 11:59 AM
Hello,
Business 80/20 BB:
I have a Netgear Nighthawk X4R7500 router connected to the OpenReach modem.
How do I discover the SNR please?
Netgear have said that I will need to access the modem for the full DSL stats.
Cheers Guy.
Business 80/20 BB:
Cheers Guy.
Message 1 of 7
(1,885 Views)
6 REPLIES 6
Re: Find Full DSL Stats for the SNR connection settings
02-07-2015 12:02 PM
you can't unless you have a modem which can be unlocked
Message 2 of 7
(965 Views)
03-07-2015 11:12 AM
I now have a modem that is unlocked and I am getting 6.8db downstream and 15.8db upstream. It's the upstream where I have issues I'm getting 14 from a potential of 20. Images are attached
I called PlusNet support today and they tell me, because my BB is FTTC, they cannot do anything regarding the SNR.
Guy
Guy
Message 3 of 7
(965 Views)
03-07-2015 11:33 AM
Your line is in sync at the maximum possible speed so a high noise margin is good
Why the upstream speed test is low I don't know but if you run this test it may give an indication http://www.thinkbroadband.com/speedtest.html?utm_source=mainsite&utm_medium=navigation&utm_campaign=...
Message 4 of 7
(965 Views)
03-07-2015 2:30 PM
Thank you for the observations.
Here's the test result link:
http://www.thinkbroadband.com/speedtest/results.html?id=1435929718131254055
and a screenshot:
and a screenshot:
Message 5 of 7
(965 Views)
03-07-2015 2:55 PM
This is beyond me but the reference to buffer bloat is perhaps part of the problem
http://forums.thinkbroadband.com/general/4405887-dslreports-new-speedtest-also-checks-for-bufferbloa...
I hope that some of the more knowledgeable posters may be able to help
One quick check
What is the MTU set in your router
One quick check
Message 6 of 7
(965 Views)
03-07-2015 3:47 PM
UMMM, BUFFERBLOAT SOUNDS SERIOUS??!!
Here are the results from the dslreprts.com test:
http://www.dslreports.com/speedtest/791358
http://www.dslreports.com/speedtest/791358.png
Cheers, Guy.
Cheers, Guy.
Message 7 of 7
(965 Views)
- Business
