Extremely S L O W portal this morning
- Business
- Re: Extremely S L O W portal this morning
11-06-2012 11:53 AM
It's taking up to 5 minutes to access pages in my member centre this morning = WHY?
Message 1 of 7
(2,800 Views)
6 REPLIES 6
11-06-2012 12:04 PM
They must have given some of your speed to me because today it's about as quick as I've ever seen it for me.
I believe there's two different datacentres with portal servers which is bourne out by repeated trace routes:
Does your trace look anything like either of those?
C:\Users\John>tracert portal.plus.net
Tracing route to portal.plus.net [212.159.9.2]
over a maximum of 30 hops:
1 1 ms 1 ms 2 ms dg834 [192.168.0.1]
2 16 ms 16 ms 16 ms lo0-central10.ptw-ag02.plus.net [195.166.128.196]
3 94 ms 202 ms 215 ms 84.93.248.32.ptw-gw01.plus.net [84.93.248.32]
4 14 ms 14 ms 14 ms xe-0-2-0.ptw-cr01.plus.net [212.159.1.16]
5 16 ms 16 ms 16 ms ae1.pcl-cr01.plus.net [195.166.129.1]
6 29 ms 15 ms 15 ms po2.pcl-gw01.plus.net [195.166.129.41]
7 22 ms 22 ms 22 ms gi5-8.ptp-cr01.plus.net [84.93.224.48]
8 23 ms 23 ms 24 ms vlan2658.ptp-elb02.plus.net [84.93.224.45]
9 66 ms 24 ms 23 ms portal.plus.net [212.159.9.2]
Trace complete.
Tracing route to portal.plus.net [212.159.8.2]
1 1 ms 2 ms 2 ms dg834 [192.168.0.1]
2 27 ms 18 ms 17 ms lo0-central10.ptw-ag02.plus.net [195.166.128.196]
3 15 ms 14 ms 15 ms 84.93.248.32.ptw-gw01.plus.net [84.93.248.32]
4 14 ms 76 ms 14 ms xe-0-2-0.ptw-cr01.plus.net [212.159.1.16]
5 159 ms 214 ms 210 ms te9-4.ptn-gw01.plus.net [195.166.129.33]
6 26 ms 27 ms 26 ms gi3-0.pih-cr1.plus.net [212.159.1.177]
7 43 ms 72 ms 33 ms if25.pih-lb04.plus.net [212.159.0.18]
8 27 ms 27 ms 27 ms portal.plus.net [212.159.8.2]
Trace complete.
Message 2 of 7
(601 Views)
11-06-2012 12:31 PM
I'm currently getting a fairly consistent thirteen second delay switching between pages in the Plusnet "Member Centre", whereas all other websites are near instantaneous.
Message 3 of 7
(601 Views)
11-06-2012 12:35 PM
I'm seeing no pages taking longer than 5 seconds, many are 1-2!
Message 4 of 7
(601 Views)
11-06-2012 12:40 PM
Good afternoon.
We're aware of an issue with one of our Core Database servers at the moment which will be causing the slowdowns you are seeing. We've raised an internal problem to investigate this and it's with our development team at present.
Apologies for the inconvenience this is causing, but we should hopefully have it sorted soon. I'll keep an eye on it and let you know if we have any more information.
Message 5 of 7
(601 Views)
11-06-2012 3:03 PM
@jelv,
Please direct me to where I conduct the traceroute...
Message 6 of 7
(601 Views)
11-06-2012 3:08 PM
Open a DOS window sometimes called Command Prompt and type in this command
Message 7 of 7
(601 Views)
- Business
