Draytek Vigor 2820n Set Up Business Broadband
Shirtcraft
After having multiple failures on a credit card security scan, I have been informed that the problem is with the PlusNet standard router.  PlusNet confirm this.
I have purchased a DrayTek 2820n to use with my business broadband.
Can anyone please advise of the settings I need to connect it in place of my PlusNet Router?
Thanks in advance.
Rob
3 REPLIES 3
JOLO
Fixes: 77
Re: Draytek Vigor 2820n Set Up Business Broadband
Hi @Shirtcraft,
The full set of connection settings can be found here.
This will be the standard connection settings, the settings to ensure that new router is PCI compliant (which I assume is what you're referring to) you'll need to speak to whoever your payment provider people are.
Fixes: 393
Hi @Shirtcraft there's a useful guide here https://support.zen.co.uk/kb/Knowledgebase/Vigor-2800-Series-Quick-Setup just replace the example zen username/password with the ones for your Plusnet account as detailed in the link provided by @JOLO
NB change the DNS settings to the OPENDNS 208.67.222.222 and 208.67.220.220, or the google ones 8.8.8.8 and 8.8.4.4
Mav
Fixes: 515
Moderator's Note(s)
Thread moved from ADSL Broadband to Business.
Forum Moderator and Customer
