Changing number while moving
- Business
- Re: Changing number while moving
17-02-2009 8:37 AM
We're moving office shortly. At the moment we have access to the new offices, and have had a phone line installed (in our name), at some stage the number of this line will change. Can we start the process of transfering our broadband connection to the current number, even though the number may change before the broadband service goes live?
Message 1 of 5
(2,750 Views)
4 REPLIES 4
17-02-2009 8:46 AM
Hi, this is entirely possible.
Your phone provider will have to perform a renumber of your line once the broadband has been moved to your new number.
Without attempting to scare you, they do sometimes get it wrong and instead of doing a 'renumber' they fully cease your line and provide it again on the new number. To avoid this you just need to ensure that they are going to perform a renumber and nothing else.
Hope this helps!
Hope this helps!
Message 2 of 5
(937 Views)
17-02-2009 8:56 AM
Thanks for your prompt response
I'm working with very sort time scales here, and can't afford to be without a broadband connection.
Sorry confused here... Is it OK to apply to transfer the broadband to the older number, but have the line renumbered while waiting for this to happen?
Quote from: Chris Your phone provider will have to perform a renumber of your line once the broadband has been moved to your new number.
Message 3 of 5
(938 Views)
17-02-2009 11:28 AM
Depending on the possible costs to your business if the move goes wrong and depending upon how much you trust BT to get it right I'd be tempted to order ADSL at the new premises on an extra line and cancel it again once the move has completed.
Message 4 of 5
(938 Views)
17-02-2009 12:41 PM
Quote from: jelv Depending on the possible costs to your business if the move goes wrong and depending upon how much you trust BT to get it right I'd be tempted to order ADSL at the new premises on an extra line and cancel it again once the move has completed.
This is an option and a perfectly valid one, depending on the budget you have for the move of your service. This is without a doubt the safest way to approach the move.
We are talking here as if you are definitely going to have problems... We do many many moves of DSL connections and a very small number of issues and I have seen loads of renumbers complete successfully.
Your phone provider will more than likely not be able to have the renumber completed whilst we are getting the DSL connection activated, but regardless of this they will do it once the broadband service is live.
Are you liaising with the business movers desk for this?
Message 5 of 5
(938 Views)
- Business
