Can somebody confirm im on an 80/20 service?
- Business
- Can somebody confirm im on an 80/20 service?
04-03-2016 4:17 PM
Hello,
Been on FTTC for quite a while now. Recently had problems with the line so I was using the openreach speed tester quite a bit.
Recently, when using the tester again, my results are suspiciously close to 40/10. I want to make sure I am actually on the 80/20 service that I'm paying for, and not 40/10
If I am on the 80/20 service then I'm probably best going to the 40/10 service
My username is mattewan
Message 1 of 5
(3,476 Views)
4 REPLIES 4
Re: Can somebody confirm im on an 80/20 service?
04-03-2016 4:21 PM
Two things
The only option for Business Customers is 80/20
For non Business Customers the options are 80/20 and 40/2
Plusnet do not offer 40/10
Message 2 of 5
(1,206 Views)
04-03-2016 4:47 PM
Why not just look at the sync speeds, or the Helpdesk page on your router? That should let you know what service you are getting.
Message 3 of 5
(1,206 Views)
05-03-2016 3:00 PM
Ahh didn't realise the only option was 80/20.... When I signed up to it when it first came out I thought I saw 40/10 as an option.
I can't see my sync speed because I have a locked ECI openreach modem which I have connected to my draytek 2830 router.
Message 4 of 5
(1,206 Views)
05-03-2016 4:52 PM
Running the BT speedtest further diagnostics to find you IP Profile (up and down) might clarify.
Message 5 of 5
(1,206 Views)
- Business
