Business credit/debit card processing
- Business
- Business credit/debit card processing
23-07-2019 1:02 PM
Hi can anyone help
I'm processing card payments through my business broadband .a scan by the card company verified a security risk .port 4567tcp is open .what is on port 4567tcp and can I change settings to make it more secure?
Message 1 of 2
(791 Views)
1 REPLY 1
Re: Business credit/debit card processing
23-07-2019 3:29 PM
This is the port used by Plusnet/BT to update your firmware. There's been a lot of discussion about this in the past. I don't think it can be closed. See also. https://community.plus.net/t5/My-Router/IP-TCP-4567/m-p/1535448#M6334
If you can't live with it then I fear that you will have to buy your own third party router.
- Business
