Business Internet is constantly dropping out
- Business
- Business Internet is constantly dropping out
10-10-2016 8:04 PM
Hi
I'm having serious problems with my internet constantly dropping out , this have been going on for weeks now and its going to wreck my business
Monday the busiest day of the week and the internet is not working
Everytime I phone plusnet they tell me the same thing , check my wiring and plug into the test socket which makes no difference
When I phone them they say theres a problem with the profile or the noise level and they make some changes which fixes the internet for a day or so
Everyday this is happening when I'm trying to do postage labels and if it goes on much longer I wont have a business anymore
Can you tell me whats happening with my internet as I cant afford to keep messing around like this
What kind of support are you giving your business customers when you say if I log a fault it might take 72 hours before somebody calls out ?
Obviously theres something wrong on your side when you can fix it for a short time everytime I call
Plusnet is not doing me proud
Re: Business Internet is constantly dropping out
11-10-2016 9:28 AM
Apologies for the issues that you're having. I can see that we reset your SNR last night prior to you posting on our forums. We're always fighting a pretty tough battle based on how long your line is from your local exchange:
That said, if you log a fault, I'll ensure that the case it picked up for you ASAP. Your line was heavily intermittent back on Friday.
Matty
17-10-2016 10:04 PM
Hi Matty
The internet is playing up again so I've logged a fault
Its been working not to bad for a while but tonight is was completely off and I had to call and get a line reset which has got me back online again
Regards
Chris2005
- Business
