Business FTTC 80/20 Trial
- Business
- Business FTTC 80/20 Trial
13-10-2012 5:02 AM
I have 2 accounts / locations on the standard 40/10 FTTC for Business trial. Is it possible to upgrade them to the 80/20 trial? I see mention of a trial is/was going ahead
http://community.plus.net/forum/index.php/topic,100419.msg875238.html#msg875238
But I don't see it as an option on http://trials.plus.net
Could someone advise? Thanks!
Message 1 of 2
(2,826 Views)
1 REPLY 1
Re: Business FTTC 80/20 Trial
15-10-2012 9:29 AM
Hi Inforr
All you'd need to do is ask a question (raise a support ticket) at http://trials.plus.net (raising it under the business FTTC option is fine) on each account, requesting that the service be upgraded to 80/20 and confirming that you accept the additional terms and conditions here - http://community.plus.net/fttc_bus_80_terms/
I recommend you check the estimated speed for each line here first - https://www.dslchecker.bt.com/pls/adsl/adslchecker.welcome If the estimated speed for FTTC is less than 40/10 then there's not much point in us placing the regrade for you as there's not much chance of a speed improvement.
I hope this helps
I hope this helps
Message 2 of 2
(314 Views)
