(Business) Downloading multiple torrent files at once
iata
When I am Downloading multiple (legal)  torrent files at the same time using my connection, the whole connection locks up and I need to reboot my router to get me online again. It sometimes works ok but other times eventually is locks up.
I am using a TP Link router as for some unusual reason on the standard plusnet router for Business connections there is no option to set the DHCP scope.
Is this normal with other users?  i wanted to check.
I may use the plusnet router again to see If it is the router that is causing the issue or the plusnet connection.
4 REPLIES 4
MatthewWheeler
Fixes: 478
Re: (Business) Downloading multiple torrent files at once
Thanks for getting in touch @iata
If you're maxing out your connection completely then you may be causing an issue known as Bufferbloat. You can find out more information regarding this here.
It may be worth setting a max download speed in your torrent client to avoid causing this in future.
 Matthew Wheeler
Fixes: 1,482
Moderators Note
This topic has been moved from ADSL Broadband to Business
iata
Possibly.
When this happens the local traffic stops and  stopping the torrent traffic does not resolve it.
I have enabled QoS and will monitor.
Jubby
All Star
Fixes: 31
No problem @iata,
Let us know how you get on, hopefully traffic prioritisation resolves the matter.
 Lewis G
 Infrastructure Operations Professional
