Broadband speed plummetted today during storm - needs IP profile resetting
- Business
- Broadband speed plummetted today during storm - ne...
Re: Broadband speed plummetted today during storm - needs IP profile resetting
25-11-2015 10:19 AM
25-11-2015 11:38 AM
Router info:
Software Release: 8.4.4.J
Software Variant: BW
Boot Loader Version: 1.0.5
And the log: Recorded Events
Time Message
Info Nov 25 11:06:03 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
Warning Nov 25 11:00:18 IDS scan parser : tcp port scan: 54.201.150.142 scanned at least 10 ports at 212.159.xxx.xx. (1 of 1) : 54.201.150.142 212.159.xxx.xx 0040 TCP 443->57035 [...R..] seq 1128186857 win 0
Error Nov 25 10:30:27 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 134.213.79.172 Dst ip: 212.159.xxx.xx Type: Destination Unreachable Code: Protocol Unreacheable
Info Nov 25 10:20:18 SNTP Synchronised again to server: 212.159.6.10
Info Nov 25 09:20:18 SNTP Synchronised again to server: 212.159.6.10
Error Nov 25 08:22:35 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 91.190.218.46 Dst ip: 212.159.xxx.xx Type: Echo Reply Code: 0
Info Nov 25 08:20:17 SNTP Synchronised again to server: 212.159.6.10
Info Nov 25 07:20:17 SNTP Synchronised again to server: 212.159.6.10
Error Nov 25 07:11:21 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 91.190.218.46 Dst ip: 212.159.xxx.xx Type: Echo Reply Code: 0
Info Nov 25 06:20:17 SNTP Synchronised again to server: 212.159.6.10
Info Nov 25 05:20:17 SNTP Synchronised again to server: 212.159.6.10
Error Nov 25 05:16:09 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 200.43.192.173 Dst ip: 212.159.xxx.xx Type: Destination Unreachable Code: Port Unreacheable
Info Nov 25 04:20:17 SNTP Synchronised again to server: 212.159.6.10
Error Nov 25 03:31:46 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 185.62.188.193 Dst ip: 212.159.xxx.xx Type: Destination Unreachable Code: Port Unreacheable
Info Nov 25 03:20:39 SNTP Synchronised again to server: 212.159.6.10
Info Nov 25 02:20:38 SNTP Synchronised to server: 212.159.6.10
Info Nov 25 01:20:38 SNTP Synchronised again to server: 212.159.13.49
Info Nov 25 01:06:08 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
Error Nov 25 00:57:50 FIREWALL replay check (1 of 1): Protocol: ICMP Src ip: 192.168.1.64 Dst ip: 216.58.210.70 Type: Destination Unreachable Code: Port Unreacheable
Info Nov 25 00:21:00 SNTP Synchronised again to server: 212.159.13.49
Info Nov 24 23:21:00 SNTP Synchronised again to server: 212.159.13.49
Info Nov 24 22:20:59 SNTP Synchronised again to server: 212.159.13.49
Info Nov 24 21:21:56 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
Info Nov 24 21:21:35 LOGIN User admin tried to login on [HTTP] (from 192.168.1.64)
Info Nov 24 21:21:00 SNTP Synchronised again to server: 212.159.13.49
Info Nov 24 20:20:59 SNTP Synchronised again to server: 212.159.13.49
Info Nov 24 20:10:42 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
Info Nov 24 19:20:59 SNTP Synchronised again to server: 212.159.13.49
Error Nov 24 18:47:35 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 149.202.xxx.xxDst ip: 212.159.xxx.xx Type: Destination Unreachable Code: Port Unreacheable
Error Nov 24 18:29:42 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 176.104.92.229 Dst ip: 212.159.xxx.xx Type: Echo Reply Code: 0
Info Nov 24 18:20:59 SNTP Synchronised again to server: 212.159.13.49
Info Nov 24 17:20:59 SNTP Synchronised again to server: 212.159.13.49
Error Nov 24 16:45:40 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 94.23.85.254 Dst ip: 212.159.xxx.xx Type: Destination Unreachable Code: Port Unreacheable
25-11-2015 12:05 PM
The Firmware isn't the latest, but if the current version is giving you a stable connection, which it seems to be, I wouldn't be rushing to upgrade - but for the record has this one got as USB socket on it? Some of those with 8.4.4.J did, others didn't.
Don't need the log every time, and that is sufficient for now anyway, you've got the hang of where to go, what to get etc.
The thing is to look at the GUI log promptly if you notice an issue with the connection - as you can see the log is full of -
"SNTP Synchronised again to server:" and can be of
"FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 94.23.85.254 Dst ip: 212.159.xxx.xx Type: Destination Unreachable Code: Port Unreacheable" also
"IDS scan parser : tcp port scan: 54.201.150.142 scanned at least 10 ports at 212.159.xxx.xx. (1 of 1) : 54.201.150.142 212.159.xxx.xx 0040 TCP 443->57035 [...R..] seq 1128186857 win 0"
and so entries that can be of use disappear from view. We can change the frequency of "SNTP Synchronised again to server:" so that it only does it every say 12 or 24 hours, I could never see the point of it doing it hourly by default
I'll post the Telnet commands in a later post, is Telnet activated on your OS .. which is?
25-11-2015 12:26 PM
Uptime: 0 days, 23:10:28
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3.936
Data Transferred (Sent/Received) [MB/GB]: 127,25 / 1,80
Output Power (Up/Down) [dBm]: 12,3 / 19,8
Line Attenuation (Up/Down) [dB]: 28,5 / 51,5
SN Margin (Up/Down) [dB]: 20,0 / 11,5
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 26 / -
FEC Errors (Up/Down): 54 / 19.851
CRC Errors (Up/Down): 1 / 34
HEC Errors (Up/Down): - / 34 / 268
25-11-2015 12:47 PM
OS? and Telnet?
25-11-2015 12:52 PM
Not sure about telnet??? How do I check?
25-11-2015 2:28 PM
Click Start > Control Panel.
Click Programs and Features.
Click Turn Windows features on or off.
In the Windows Features dialog box, check the Telnet Client check box.
Click OK. The system installs the relevant files.
Pictures if they help can be seen here Also, are you familiar with opening a Command Prompt Window?
25-11-2015 5:12 PM
25-11-2015 5:37 PM
What I do is dump the output to a file (the -f is to send it to a file named events##.log) by typing the following
telnet -f events##.log 192.168.1.254
you get prompted for your TG582n username (default is admin in lower case as you probably know and the password begins CP as you probably know. At the telnet prompt type
syslog msgbuf show hist=enabled
When the output has finished, type exit at the prompt.
You can look at the folder listing of the file(s) using Windows Explorer or what ever you choose to view folders and files.
What I do then is rename the telnet##.log file replacing the ## with a number, 01 for the first, 02 for the second etc. assuming you want to keep them. By doing it that way I don't have to remember what number I got to when doing the Telnet command for the nth time If you don't rename it, the next one you do will just overwrite the previous.
You can open that log file in a text viewer and do a copy and paste not forgetting to redact you Dst ip: address.
27-11-2015 9:41 AM
It would probably be a good idea to start thinking about a bit of automated monitoring which might give us some feel for how intermittent the problem is that you don't actually notice because it doesn't cause a loss of sync every time.
29-11-2015 5:11 PM
Apologies for the delay ... life caught up with me!
I'm not seeing a telnet log ... I've attached the screenshot I get when I try the cmd telnet /? ... any ideas how to fix this/
Best wishes
Anne
29-11-2015 6:10 PM
29-11-2015 8:11 PM
Here is the log:
{admin}=>syslog msgbuf show hist=enabled
<82> Jan 1 00:00:28 UPnP framework disabled
<82> Jan 1 00:00:30 UPnP framework disabled
<85> Jan 1 00:00:36 FIREWALL event (1 of 1): created rules
<85> Jan 1 00:00:36 FIREWALL event (1 of 1): modified rules
<82> Jan 1 00:00:36 UPnP framework enabled
<85> Jan 1 00:00:38 FIREWALL level changed to Standard.
<85> Jan 1 00:00:38 FIREWALL event (1 of 1): deleted rules
<148> Jan 1 00:00:38 DHCS server up
<173> Jan 1 00:00:44 xDSL linestate up (ITU-T G.992.1; downstream: 3936 kbit/s,
upstream: 448 kbit/s; output Power Down: 19.6 dBm, Up: 12.3 dBm; line Attenuati
on Down: 51.5 dB, Up: 28.5 dB; snr Margin Down: 12.3 dB, Up: 20.0 dB)
<3> Jan 1 00:01:00 [ANTI_SPOOFD] (err) llist_getobject_at for ENV.ANTI_SPOOFD's
value failed
<39> Jan 1 00:01:02 PPP CHAP Receive challenge (rhost = ERX20.Edinburgh4)
<39> Jan 1 00:01:03 PPP CHAP Receive challenge (rhost = PCL-AG02)
<38> Jan 1 00:01:03 PPP CHAP Chap receive success : authentication ok
<132> Jan 1 00:01:04 PPP link up (Internet) [212.159.xxx.xx]
<85> Jan 1 00:01:04 FIREWALL event (1 of 6): deleted rules
<14> Jan 1 00:03:01 CONFIGURATION saved by TR69
<37> Jan 1 00:03:02 LOGIN wireless station [e0:06:e6:02:4c:5b] can't get author
ized.
<37> Jan 1 00:04:02 LOGIN wireless station [e0:06:e6:02:4c:5b] can't get author
ized.
<99> Nov 24 13:21:20 SNTP Systemtime update: time setting 00:05:50 > new time se
tting: 13:21:20
<102> Nov 24 13:21:20 SNTP Synchronised to server: 212.159.13.49
<37> Nov 24 13:24:09 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
<102> Nov 24 14:21:20 SNTP Synchronised again to server: 212.159.13.49
<81> Nov 24 15:08:00 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 46.30
.212.108 Dst ip: 212.159.xxx.xx Type: Echo Reply Code: 0
<81> Nov 24 15:15:10 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 151.8
0.108.136 Dst ip: 212.159.xxx.xx Type: Destination Unreachable Code: Port Unreach
eable
<102> Nov 24 15:21:20 SNTP Synchronised again to server: 212.159.13.49
<81> Nov 24 15:40:53 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 219.1
58.11.173 Dst ip: 212.159.xxx.xx Type: Time Exceeded Code: Time to Live exceeded
in Transit
<102> Nov 24 16:20:58 SNTP Synchronised again to server: 212.159.13.49
<37> Nov 24 16:25:38 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
<37> Nov 24 16:43:07 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
<81> Nov 24 16:45:40 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 94.23
ble
<102> Nov 24 17:20:59 SNTP Synchronised again to server: 212.159.13.49
<102> Nov 24 18:20:59 SNTP Synchronised again to server: 212.159.13.49
<81> Nov 24 18:29:42 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 176.1
<81> Nov 24 18:47:35 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 149.2
02.107.63 Dst ip: 212.159.xxx.xx Type: Destination Unreachable Code: Port Unreach
eable
<102> Nov 24 19:20:59 SNTP Synchronised again to server: 212.159.13.49
<37> Nov 24 20:10:42 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
<102> Nov 24 20:20:59 SNTP Synchronised again to server: 212.159.13.49
<102> Nov 24 21:21:00 SNTP Synchronised again to server: 212.159.13.49
<37> Nov 24 21:21:35 LOGIN User admin tried to login on [HTTP] (from 192.168.1.6
4)
<37> Nov 24 21:21:56 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
<102> Nov 24 22:20:59 SNTP Synchronised again to server: 212.159.13.49
<102> Nov 24 23:21:00 SNTP Synchronised again to server: 212.159.13.49
<102> Nov 25 00:21:00 SNTP Synchronised again to server: 212.159.13.49
<81> Nov 25 00:57:50 FIREWALL replay check (1 of 1): Protocol: ICMP Src ip: 192
eable
<37> Nov 25 01:06:08 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
<102> Nov 25 01:20:38 SNTP Synchronised again to server: 212.159.13.49
<102> Nov 25 02:20:38 SNTP Synchronised to server: 212.159.6.10
<102> Nov 25 03:20:39 SNTP Synchronised again to server: 212.159.6.10
<81> Nov 25 03:31:46 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 185.6
eable
<102> Nov 25 04:20:17 SNTP Synchronised again to server: 212.159.6.10
<81> Nov 25 05:16:09 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 200.4
eable
<102> Nov 25 05:20:17 SNTP Synchronised again to server: 212.159.6.10
<102> Nov 25 06:20:17 SNTP Synchronised again to server: 212.159.6.10
<81> Nov 25 07:11:21 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 91.19
<102> Nov 25 07:20:17 SNTP Synchronised again to server: 212.159.6.10
<102> Nov 25 08:20:17 SNTP Synchronised again to server: 212.159.6.10
<81> Nov 25 08:22:35 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 91.19
<102> Nov 25 09:20:18 SNTP Synchronised again to server: 212.159.6.10
<102> Nov 25 10:20:18 SNTP Synchronised again to server: 212.159.6.10
<81> Nov 25 10:30:27 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 134.2
eacheable
<84> Nov 25 11:00:18 IDS scan parser : tcp port scan: 54.201.150.142 scanned at
<37> Nov 25 11:06:03 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
<102> Nov 25 11:20:18 SNTP Synchronised again to server: 212.159.6.10
<37> Nov 25 12:19:12 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
<102> Nov 25 12:20:18 SNTP Synchronised again to server: 212.159.6.10
<37> Nov 25 12:55:03 LOGIN wireless station [e0:06:e6:02:4c:5b] can't get author
ized.
<102> Nov 25 13:20:18 SNTP Synchronised again to server: 212.159.6.10
<102> Nov 25 14:20:19 SNTP Synchronised again to server: 212.159.6.10
<102> Nov 25 15:20:19 SNTP Synchronised again to server: 212.159.6.10
<81> Nov 25 15:38:53 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 134.2
eacheable
<102> Nov 25 16:20:19 SNTP Synchronised again to server: 212.159.6.10
<81> Nov 25 17:17:27 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 87.22
9.220.174 Dst ip: 212.159.xxx.xx Type: Time Exceeded Code: Time to Live exceeded
in Transit
<102> Nov 25 17:20:19 SNTP Synchronised again to server: 212.159.6.10
<81> Nov 25 17:49:33 FIREWALL icmp check (1 of 2): Protocol: ICMP Src ip: 91.19
<102> Nov 25 18:20:19 SNTP Synchronised again to server: 212.159.6.10
<81> Nov 25 18:26:52 FIREWALL replay check (1 of 5): Protocol: ICMP Src ip: 192
.168.1.65 Dst ip: 157.55.235.171 Type: Destination Unreachable Code: Port Unreac
heable
<81> Nov 25 18:31:11 FIREWALL replay check (1 of 8): Protocol: ICMP Src ip: 192
.168.1.65 Dst ip: 157.56.198.41 Type: Destination Unreachable Code: Port Unreach
eable
<81> Nov 25 18:33:46 FIREWALL replay check (1 of 9): Protocol: ICMP Src ip: 192
.168.1.65 Dst ip: 185.34.60.74 Type: Destination Unreachable Code: Port Unreache
able
<81> Nov 25 18:39:55 FIREWALL replay check (1 of 5): Protocol: ICMP Src ip: 192
heable
<81> Nov 25 18:46:42 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 108.6
3.96.1 Dst ip: 212.159.xxx.xx Type: Destination Unreachable Code: Fragmentation N
eeded and Don't Fragment was Set
<81> Nov 25 18:55:16 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
.168.1.65 Dst ip: 94.173.25.116 Type: Destination Unreachable Code: Port Unreach
eable
<81> Nov 25 19:04:53 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<102> Nov 25 19:20:19 SNTP Synchronised again to server: 212.159.6.10
<102> Nov 25 20:20:19 SNTP Synchronised again to server: 212.159.6.10
<102> Nov 25 21:20:20 SNTP Synchronised again to server: 212.159.6.10
<81> Nov 25 21:42:06 FIREWALL replay check (1 of 4): Protocol: ICMP Src ip: 192
eable
<81> Nov 25 21:47:54 FIREWALL replay check (1 of 4): Protocol: ICMP Src ip: 192
.168.1.65 Dst ip: 101.179.28.78 Type: Destination Unreachable Code: Port Unreach
eable
<81> Nov 25 21:48:59 FIREWALL replay check (1 of 5): Protocol: ICMP Src ip: 192
eable
<81> Nov 25 21:52:47 FIREWALL replay check (1 of 3): Protocol: ICMP Src ip: 192
eable
<81> Nov 25 21:57:35 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
.168.1.65 Dst ip: 41.242.137.31 Type: Destination Unreachable Code: Port Unreach
eable
<81> Nov 25 22:03:27 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 25 22:05:52 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 25 22:07:03 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<81> Nov 25 22:17:57 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<102> Nov 25 22:20:20 SNTP Synchronised again to server: 212.159.6.10
<81> Nov 25 22:30:59 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<81> Nov 25 22:36:35 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 25 22:40:36 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
.168.1.65 Dst ip: 154.120.114.66 Type: Destination Unreachable Code: Port Unreac
heable
<81> Nov 25 22:42:57 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 178.3
3.164.233 Dst ip: 212.159.xxx.xx Type: Destination Unreachable Code: Communicatio
n with Destination Host is Administratively Prohibited
<81> Nov 25 22:46:55 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 25 22:52:09 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<81> Nov 25 22:55:31 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
heable
<81> Nov 25 22:57:14 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 25 23:02:25 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<81> Nov 25 23:07:34 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 25 23:13:11 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<81> Nov 25 23:17:52 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<102> Nov 25 23:20:20 SNTP Synchronised again to server: 212.159.6.10
<81> Nov 25 23:23:46 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<81> Nov 25 23:28:13 FIREWALL replay check (1 of 1): Protocol: ICMP Src ip: 192
eable
<81> Nov 25 23:33:56 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<81> Nov 25 23:38:33 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 25 23:40:16 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<102> Nov 26 00:20:20 SNTP Synchronised to server: 212.159.6.9
<102> Nov 26 01:20:20 SNTP Synchronised again to server: 212.159.6.9
<81> Nov 26 01:36:28 FIREWALL icmp check (1 of 2): Protocol: ICMP Src ip: 93.17
4.93.239 Dst ip: 212.159.xxx.xx Type: Destination Unreachable Code: Port Unreache
able
<102> Nov 26 02:20:20 SNTP Synchronised again to server: 212.159.6.9
<84> Nov 26 03:01:20 IDS proto parser : tcp null port (1 of 1) : 190.90.121.131
212.159.xxx.xx 0060 TCP 0->23 [S.....] seq 1536818437 win 5840
<102> Nov 26 03:20:20 SNTP Synchronised again to server: 212.159.6.9
<102> Nov 26 04:20:20 SNTP Synchronised again to server: 212.159.6.9
<102> Nov 26 05:20:20 SNTP Synchronised again to server: 212.159.6.9
<81> Nov 26 06:19:19 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 91.19
0.218.46 Dst ip: 212.159.xxx.xx Type: Destination Unreachable Code: Port Unreache
able
<102> Nov 26 06:19:59 SNTP Synchronised again to server: 212.159.6.9
<102> Nov 26 07:19:59 SNTP Synchronised again to server: 212.159.6.9
<102> Nov 26 08:19:59 SNTP Synchronised again to server: 212.159.6.9
<81> Nov 26 08:59:09 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 09:00:12 FIREWALL replay check (1 of 4): Protocol: ICMP Src ip: 192
able
<81> Nov 26 09:09:50 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<102> Nov 26 09:19:59 SNTP Synchronised again to server: 212.159.6.9
<81> Nov 26 09:20:36 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 09:30:23 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 09:33:55 FIREWALL replay check (1 of 4): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 09:40:42 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 09:44:29 FIREWALL replay check (1 of 3): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 09:49:50 FIREWALL replay check (1 of 4): Protocol: ICMP Src ip: 192
able
<81> Nov 26 09:51:03 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 09:54:43 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 09:58:04 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
.168.1.65 Dst ip: 157.55.235.149 Type: Destination Unreachable Code: Port Unreac
heable
<81> Nov 26 10:01:23 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 10:05:46 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 10:16:01 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<102> Nov 26 10:19:59 SNTP Synchronised again to server: 212.159.6.9
<81> Nov 26 10:22:06 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 10:32:27 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 10:42:47 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 10:53:07 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 10:58:57 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
.168.1.65 Dst ip: 41.218.248.205 Type: Destination Unreachable Code: Port Unreac
heable
<81> Nov 26 11:08:51 FIREWALL replay check (1 of 5): Protocol: ICMP Src ip: 192
able
<81> Nov 26 11:13:58 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<102> Nov 26 11:19:59 SNTP Synchronised again to server: 212.159.6.9
<81> Nov 26 11:24:33 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 11:27:16 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
.168.1.65 Dst ip: 58.191.162.198 Type: Destination Unreachable Code: Port Unreac
heable
<81> Nov 26 11:28:31 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<81> Nov 26 11:30:31 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<81> Nov 26 11:34:54 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 11:47:10 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 91.19
able
<81> Nov 26 11:48:08 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<81> Nov 26 11:50:20 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
heable
<81> Nov 26 11:50:41 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 91.19
able
<81> Nov 26 11:55:44 FIREWALL replay check (1 of 4): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 11:58:23 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<81> Nov 26 12:06:01 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 12:07:38 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
heable
<81> Nov 26 12:10:16 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<81> Nov 26 12:16:21 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 12:18:18 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
heable
<102> Nov 26 12:19:59 SNTP Synchronised again to server: 212.159.6.9
<81> Nov 26 12:20:31 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<81> Nov 26 12:23:34 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
heable
<81> Nov 26 12:26:40 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 12:27:56 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
.168.1.65 Dst ip: 154.70.64.57 Type: Destination Unreachable Code: Port Unreache
able
<81> Nov 26 12:30:46 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<81> Nov 26 12:36:59 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 12:39:39 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
.168.1.65 Dst ip: 213.199.179.150 Type: Destination Unreachable Code: Port Unrea
cheable
<81> Nov 26 12:42:13 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<81> Nov 26 12:47:18 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 12:58:01 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 13:08:22 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<102> Nov 26 13:20:00 SNTP Synchronised again to server: 212.159.6.9
<81> Nov 26 13:29:05 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 13:49:46 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 14:00:05 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 14:17:09 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<102> Nov 26 14:20:00 SNTP Synchronised again to server: 212.159.6.9
<81> Nov 26 14:20:44 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 14:26:33 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
.168.1.65 Dst ip: 65.55.223.45 Type: Destination Unreachable Code: Port Unreache
able
<81> Nov 26 14:31:05 FIREWALL replay check (1 of 4): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 14:37:34 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
.168.1.65 Dst ip: 31.80.36.186 Type: Destination Unreachable Code: Port Unreache
able
<81> Nov 26 14:41:48 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
.168.1.65 Dst ip: 157.55.235.146 Type: Destination Unreachable Code: Port Unreac
heable
<81> Nov 26 14:47:29 FIREWALL replay check (1 of 4): Protocol: ICMP Src ip: 192
able
<81> Nov 26 14:51:43 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 15:02:04 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 15:12:23 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<102> Nov 26 15:20:00 SNTP Synchronised again to server: 212.159.6.9
<81> Nov 26 15:22:47 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 15:36:46 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<102> Nov 26 16:19:38 SNTP Synchronised again to server: 212.159.6.9
<81> Nov 26 16:31:54 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 16:38:18 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 16:41:29 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
heable
<81> Nov 26 16:59:39 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 17:00:52 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 91.19
<102> Nov 26 17:19:38 SNTP Synchronised again to server: 212.159.6.9
<81> Nov 26 17:22:54 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
.168.1.65 Dst ip: 216.58.208.34 Type: Destination Unreachable Code: Port Unreach
eable
<81> Nov 26 17:30:34 FIREWALL replay check (1 of 5): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 17:53:01 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 18:14:06 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<102> Nov 26 18:19:38 SNTP Synchronised again to server: 212.159.6.9
<81> Nov 26 18:25:05 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<81> Nov 26 18:45:51 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
eable
<102> Nov 26 19:19:39 SNTP Synchronised again to server: 212.159.6.9
<81> Nov 26 19:53:59 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<81> Nov 26 20:16:51 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<102> Nov 26 20:19:39 SNTP Synchronised again to server: 212.159.6.9
<81> Nov 26 20:39:18 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<81> Nov 26 21:07:16 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 93.17
4.93.239 Dst ip: 212.159.xxx.xx Type: Echo Reply Code: 0
<81> Nov 26 21:09:20 FIREWALL replay check (1 of 5): Protocol: ICMP Src ip: 192
able
<102> Nov 26 21:19:39 SNTP Synchronised to server: 212.159.13.49
<81> Nov 26 21:33:38 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<81> Nov 26 21:43:53 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<81> Nov 26 21:54:09 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
able
<102> Nov 26 22:19:39 SNTP Synchronised again to server: 212.159.13.49
<102> Nov 26 23:19:39 SNTP Synchronised again to server: 212.159.13.49
<81> Nov 26 23:44:54 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 91.19
able
<102> Nov 27 00:19:39 SNTP Synchronised again to server: 212.159.13.49
<102> Nov 27 01:19:39 SNTP Synchronised again to server: 212.159.13.49
<81> Nov 27 01:26:37 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 91.19
<102> Nov 27 02:19:39 SNTP Synchronised again to server: 212.159.13.49
<102> Nov 27 03:19:39 SNTP Synchronised again to server: 212.159.13.49
<102> Nov 27 04:19:39 SNTP Synchronised again to server: 212.159.13.49
<102> Nov 27 05:19:39 SNTP Synchronised again to server: 212.159.13.49
<102> Nov 27 06:19:39 SNTP Synchronised again to server: 212.159.13.49
<102> Nov 27 07:19:40 SNTP Synchronised again to server: 212.159.13.49
<84> Nov 27 08:03:08 IDS scan parser : tcp port scan: 212.56.73.17 scanned at le
ast 10 ports at 212.159.xxx.xx. (1 of 2) : 212.56.73.17 212.159.xxx.xx 0040
TCP 80->60261 [...R..] seq 2253104581 win 0
<81> Nov 27 08:10:37 FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 192
.168.1.65 Dst ip: 216.58.208.66 Type: Destination Unreachable Code: Port Unreach
eable
<102> Nov 27 08:19:40 SNTP Synchronised again to server: 212.159.13.49
<81> Nov 27 08:57:10 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 195.2
11.193.27 Dst ip: 212.159.xxx.xx Type: Destination Unreachable Code: Port Unreach
eable
<102> Nov 27 09:19:40 SNTP Synchronised again to server: 212.159.13.49
<102> Nov 27 10:19:40 SNTP Synchronised again to server: 212.159.13.49
<84> Nov 27 10:53:36 IDS scan parser : tcp port scan: 31.13.90.36 scanned at lea
st 10 ports at 212.159.xxx.xx. (1 of 2) : 31.13.90.36 212.159.xxx.xx 0040 T
CP 443->60891 [...R..] seq 3144262352 win 0
<102> Nov 27 11:19:40 SNTP Synchronised again to server: 212.159.13.49
<102> Nov 27 12:19:40 SNTP Synchronised again to server: 212.159.13.49
<102> Nov 27 13:19:40 SNTP Synchronised again to server: 212.159.13.49
<81> Nov 27 13:25:35 FIREWALL icmp check (1 of 2): Protocol: ICMP Src ip: 185.8
1.155.247 Dst ip: 212.159.xxx.xx Type: Destination Unreachable Code: Port Unreach
eable
<102> Nov 27 14:19:40 SNTP Synchronised again to server: 212.159.13.49
<102> Nov 27 15:19:40 SNTP Synchronised again to server: 212.159.13.49
<102> Nov 27 16:19:19 SNTP Synchronised again to server: 212.159.13.49
<102> Nov 27 17:19:19 SNTP Synchronised again to server: 212.159.13.49
<102> Nov 27 18:19:19 SNTP Synchronised again to server: 212.159.13.49
<102> Nov 27 19:19:19 SNTP Synchronised to server: 212.159.13.50
<102> Nov 27 20:19:19 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 27 21:19:19 SNTP Synchronised again to server: 212.159.13.50
<84> Nov 27 21:28:38 IDS scan parser : tcp port scan: 31.13.90.2 scanned at leas
t 10 ports at 212.159.xxx.xx. (1 of 2) : 31.13.90.2 212.159.xxx.xx 0040 TC
P 443->50215 [...R..] seq 2319877851 win 0
<81> Nov 27 21:31:55 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 93.17
<102> Nov 27 22:19:19 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 27 23:19:19 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 28 00:19:20 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 28 01:19:20 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 28 02:18:58 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 28 03:18:58 SNTP Synchronised again to server: 212.159.13.50
<81> Nov 28 04:15:09 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 93.17
able
<102> Nov 28 04:18:58 SNTP Synchronised again to server: 212.159.13.50
<84> Nov 28 05:06:59 IDS scan parser : tcp port scan: 208.82.16.87 scanned at le
ast 10 ports at 212.159.xxx.xx. (1 of 2) : 208.82.16.87 212.159.xxx.xx 0094
TCP 80->51241 [..AR..] seq 4067011054 ack 2202114745 win 0
<102> Nov 28 05:18:59 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 28 06:18:59 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 28 07:18:59 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 28 08:18:59 SNTP Synchronised again to server: 212.159.13.50
<81> Nov 28 08:28:38 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 91.19
<102> Nov 28 09:18:59 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 28 10:18:59 SNTP Synchronised again to server: 212.159.13.50
<81> Nov 28 10:35:53 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 5.200
.23.140 Dst ip: 212.159.xxx.xx Type: Destination Unreachable Code: Port Unreachea
ble
<102> Nov 28 11:18:59 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 28 12:18:59 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 28 13:18:59 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 28 14:18:59 SNTP Synchronised again to server: 212.159.13.50
<81> Nov 28 14:56:17 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 91.19
able
<102> Nov 28 15:18:59 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 28 16:18:59 SNTP Synchronised again to server: 212.159.13.50
<84> Nov 28 16:50:07 IDS scan parser : tcp port scan: 208.82.16.87 scanned at le
ast 10 ports at 212.159.xxx.xx. (1 of 1) : 208.82.16.87 212.159.xxx.xx 0094
TCP 80->53797 [..AR..] seq 3012555474 ack 771170388 win 0
<102> Nov 28 17:19:00 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 28 18:19:00 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 28 19:19:00 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 28 20:19:00 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 28 21:19:00 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 28 22:19:00 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 28 23:19:00 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 29 00:19:00 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 29 01:19:00 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 29 02:19:00 SNTP Synchronised again to server: 212.159.13.50
<84> Nov 29 03:00:52 IDS scan parser : tcp port scan: 54.88.173.29 scanned at le
ast 10 ports at 212.159.xxx.xx. (1 of 1) : 54.88.173.29 212.159.xxx.xx 0040
TCP 443->61391 [...R..] seq 3068353280 win 0
<102> Nov 29 03:19:00 SNTP Synchronised again to server: 212.159.13.50
<81> Nov 29 03:28:20 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 180.8
7.180.66 Dst ip: 212.159.xxx.xx Type: Time Exceeded Code: Time to Live exceeded i
n Transit
<102> Nov 29 04:19:01 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 29 05:19:01 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 29 06:19:01 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 29 07:19:01 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 29 08:19:01 SNTP Synchronised again to server: 212.159.13.50
<81> Nov 29 08:56:38 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 149.2
02.196.129 Dst ip: 212.159.xxx.xx Type: Destination Unreachable Code: Port Unreac
heable
<102> Nov 29 09:19:01 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 29 10:19:01 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 29 11:19:01 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 29 12:19:01 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 29 13:19:01 SNTP Synchronised again to server: 212.159.13.50
<102> Nov 29 14:19:01 SNTP Synchronised to server: 212.159.6.10
<84> Nov 29 14:23:39 IDS scan parser : tcp port scan: 68.232.34.200 scanned at l
east 10 ports at 212.159.xxx.xx. (1 of 1) : 68.232.34.200 212.159.xxx.xx 0040
TCP 443->61456 [...R..] seq 1702480894 win 0
<81> Nov 29 15:10:07 FIREWALL replay check (1 of 7): Protocol: ICMP Src ip: 192
.168.1.64 Dst ip: 216.58.208.34 Type: Destination Unreachable Code: Port Unreach
eable
<102> Nov 29 15:19:01 SNTP Synchronised again to server: 212.159.6.10
<102> Nov 29 16:19:02 SNTP Synchronised again to server: 212.159.6.10
<102> Nov 29 17:19:02 SNTP Synchronised again to server: 212.159.6.10
<102> Nov 29 18:19:02 SNTP Synchronised again to server: 212.159.6.10
<102> Nov 29 19:19:02 SNTP Synchronised again to server: 212.159.6.10
<37> Nov 29 19:59:04 LOGIN User admin logged in on TELNET (192.168.1.64)
{admin}=>exit
30-11-2015 4:10 PM
As you can see, the log has got a lot of those hourly SNTP entries filling it up, but never the less not too many that it still goes back (just - bar 28 seconds) to when the 582n last booted up on the 24th. Entries with a code <132> and a code <173> are ones to try and spot when having a quick glance at the file if there are any issues.
Looking at entries prior to <173> can be important especially the ones that would say things like "Kernel Cold Restart" or "Kernel Warm Restart". The former occur at a power up (& obviously after a power interruption), the latter if something triggers a Reboot.
You'll note the entries that are Jan 1, they are part of the boot sequence that occurs before the the first SNTP synchronisation (which usually happens in the first 5 minutes). If we were still on BST there would be an hour jump on one of the entries after the first SNTP.
Now we can reduce the frequency of he SNTP checks, how frequently do you want it to do it? It's not exactly critical. I personally changed mine to every 24hrs.
I'll post up how to do that in my next post.
The log also obviously shows you've not had a drop in sync since boot - some 5 1/4 days previously at time of your posting. So some good news.
30-11-2015 6:47 PM
Good to know the line has been stable for the past few days. We haven't had any wild weather yet, tho the forecast is for some wild weather in the early hours of Wednesday morning, so we'll see how the line copes with that
If there are some lines of no interest, i could replace them with a blank if that would make it easier to spot the interesting bits?
Best wishes
Anne
- Business
