Broadband speed plummetted today during storm - needs IP profile resetting
- Business
- Broadband speed plummetted today during storm - ne...
- « Previous
- Next »
Re: Broadband speed plummetted today during storm - needs IP profile resetting
30-11-2015 7:14 PM
If we get rid of most of the SNTP entries as they fill the log that will be more beneficial - just deleting them from a copy isn't a real help.
You need to Telnet in. I also save my commands to a file so I know what I've changed. I use telnet as follows -
telnet -f telnet##.log 192.168.1.254
Then after I'm done I change the ## to a number by renaming the file, so the first one becomes telnet01.log
The polling is set in minutes, so for 24hrly use the following commands -
sntp config poll=1440
saveall
exit
The other little trick I use is to keep all these telnet commands in a text file. So when I want to use them, I just do a copy and paste of the command to the relevant prompt - this saves typing the more complicated ones with the possibility of typos, never mind the problem of sometimes forgetting them
saveall
exit
Message 46 of 48
(640 Views)
02-12-2015 2:20 AM
I'm getting stuck now at the telnet prompt. It welcomes me to Telnet, and says 'microsoft telnet>' but it doesn't ask for my login details.
At what point should the:
saveall
exit
command be entered?
saveall
exit
command be entered?
Message 47 of 48
(640 Views)
02-12-2015 5:37 AM
Are you either typing the full telnet command at a command prompt, ie -
or if you don't want a copy saved to a file
telnet 192.168.1.254
or at the Telnet prompt (could be OS dependant - type ? for help usually) it's o for open
o 192.168.1.254
Only when logged into the 582n with telnet do you type the:
saveall
exit
If perchance you get a message about already 2 telnet sessions running on the 582n, then follow the instructions and kill one or both.
o 192.168.1.254
saveall
exit
Message 48 of 48
(640 Views)
- « Previous
- Next »
- Business
