Bonded ADSL
- Business
- Bonded ADSL
Bonded ADSL
24-04-2008 10:55 AM
This is just a simple question, That I have been asked by some of my clients
Plus Net do you support ADSL BONDING via MLPPP
If not are there any plans in the pipe line to do so
Thank you
Moderators note by James_H : changed title from all caps. : Please read the link:rules
Re: Bonded ADSL
24-04-2008 1:59 PM
We don't currently, but are looking into potential solutions that we may be able to offer in the future.
Re: Bonded ADSL
24-04-2008 2:50 PM
just a quick question to satisfy my curiosity
If one had two ADSL feeds into a switch would there be an improvement in speed?
Re: Bonded ADSL
24-04-2008 2:51 PM
Not currently. It probably just wouldn't work.
Re: Bonded ADSL
24-04-2008 2:59 PM
Just a thought
<mcgurka territory./>
Re: Bonded ADSL
24-04-2008 3:17 PM
Quote from: Jameseh As in two telephone lines, both with broadband going into one router?
I was thinking along these lines
ADSL 1----------------------- R1
--------------------------ES------------------PC
ADSL2------------------------R2
Router 1 and router 2 (two separate ADSL feeds) linked together connecting them to a switch
apologies for the crude diagram
Re: Bonded ADSL
24-04-2008 3:20 PM
Either that or a nice hefty Cisco router
B.
Re: Bonded ADSL
24-04-2008 4:12 PM
Thankyou Jameseh for your reply
I and some on my clients would be intrested in the service if it is made avalable
for thoes who dont know the diffrence
Load balance verses Bonded ADSL
Load balanceing accross multi ADSLs help with the amount of date moved but not on speed.
Bonded ADSL make all the adsls look like one big fat pipe and there for helps with speed.
Hope to here some news then Jameseh
thank you
Re: Bonded ADSL
24-04-2008 6:54 PM
Good to hear of your interest in a bonded solution.
As James has mentioned this is something my colleagues in the Products team and I are currently working on. It helps when we know of new customers who are interested in this sort of solution.
As part of our current Partner programme www.plus.net/partners we have established that there is quite a bit of demand for this service. If you want to drop me a PM I'd be interested to learn more about your requirements.
Look forward to hearing from you.
Re: Bonded ADSL
24-04-2008 7:52 PM
Quote from: kplahnet Hi All
thank you
Well yes! But it is still asynchronous? More up than down - so if you are planning to put servers at each end of the link, you are limited to the slowest speed for data Xfer. Its only OK if your needs match the capability?
Re: Bonded ADSL
13-11-2008 3:22 PM
Quote 123Telecom can DOUBLE the speed of your Business Broadband in 3 easy steps.
Step 1. Transfer your current Broadband service to 123Telecom.
Step 2. Order a second Broadband service from 123Telecom.
Step 3. Upgrade your Internet router to a CISCO "DoubleSpeed" unit from 123Telecom
123Telecom DoubleSpeed broadband is just £68 per month (£34 per line).
Would you like me to forward more information?
Answer: no thanks we have it coming..... don't we?
Re: Bonded ADSL
13-11-2008 3:27 PM
Re: Bonded ADSL
14-11-2008 1:52 PM
Re: Bonded ADSL
14-11-2008 1:58 PM
What's key to point out is that this sort of bonded solution is still ADSL. It does not and will not offer the SLA's that a leased line will.
Re: Bonded ADSL
14-11-2008 2:22 PM
Depends what your connection is supporting, for example where I work it would not be suitable as we have around 3000 host systems.
