BT Speed Test Result
fceluk
What does the bold 2000 Kbps imply in an up to 8Mbs product Undecided
Is the line capped at 2Mbs?
Quote from: BT
Test1 comprises of Best Effort Test: -provides background information.
Download  Speed
1142 Kbps
0 Kbps 2000 Kbps Max Achievable Speed
Download speedachieved during the test was - 1142 Kbps
For your connection, the acceptable range of speeds is 800-2000 Kbps.
Additional Information:
Your DSL Connection Rate :1824 Kbps(DOWN-STREAM), 832 Kbps(UP-STREAM)
IP Profile for your line is - 1250 Kbps.
4 REPLIES 4
fceluk
Re: BT Speed Test Result
Update.
Dropped a ticket into the 19 hour queue and it was answered within 4 hours.
The requested SNRM reset done with a drop to 6.5 with D/L speed climbing up past 2.5Mbs.
Brilliant service ( it is a business line though )
fceluk
If anyone happens to be passing can they give my PN profile a kick to match the BT one Smiley
Jake
Hi fcel,
I've update our profile for you to 2000, to match the two profiles up. May need a single one-off reboot of the router to pick up this profile.
Strat
Fixes: 565
Thanks Jake. Smiley
Windows 10 Firefox 107.0 (64-bit)
