ADSL2+ For Business
- Business
- Re: ADSL2+ For Business
ADSL2+ For Business
26-10-2009 7:20 PM
I was just hoping that someone at Plusnet could shed some light on there plans for ADSL2+ for business customers. See I'm looking to change packages for a couple of sites that I look after but if Plusnet are going to introduce new packages for ADSL2+ within the next few months then I'll hold off for the time being.
Rich
26-10-2009 11:17 PM
Plusnet recently introduced a pretty competitive set of new business products. Don't know if you've seen them? http://www.plus.net/business
Because this was quite recently, they focussed on getting residential ADSL2+ sorted first. I think also partly because Business connections are arguably more critical so it gives Plusnet some time to allow ADSL2+ to bed in 'en masse'.
They have said they will be looking at ADSL2+ for business early next year though. It's not available at my business' exchange just yet but I too am waiting to hear more!
Cheers,
Liam
18-12-2009 7:52 PM
20-01-2010 8:13 AM
However, we've had no notifications of any migration sent to the e-mail address that our billing notification goes to, so maybe it's not the case and we're still on the normal connections.
20-01-2010 9:33 AM
20-01-2010 9:58 AM
Quote We also appear to have been migrated to the 21CN network as checking the gateway we're on is PCL-AG04
PCL-AG04 is also used to terminate 20CN connections, your line isn't on 21CN.
04-02-2010 3:22 PM
13-09-2010 2:21 PM
Many business users are 'teleworkers' and their connections are also as a normal family broadband connection.
So how about it PlusNet - why not give us the option of moving to ADSL 2+?
Tony
14-09-2010 7:20 AM
Rob
15-09-2010 12:46 PM
However, any business customer can be moved over, at their request. Please just raise a ticket.
24-09-2010 9:09 AM
I understand from posts elsewhere that the fault rate is about 4% (1 in 25). If you currently have a good, stable, high IP profile connection to a 21CN enabled, then you could certainly consider moving to ADSL2+.
Tony
