yet another speed question
- yet another speed question
11-11-2011 9:25 AM
I've been a customer for a few years now. Since I signed up I've had a connection speed of about 0.5 Meg (ip profile of 500 KBps), and put it down to living in the middle of nowhere, quality of the line, etc, and just got on with it as I didn't have much of a clue about broadband. However, a couple of months back BT fixed a fault on our line after high winds knocked something loose at one of the nearby poles and after a while I noticed the connection jumped to around 2 Meg. This lasted for about a month, then dropped back to normal, but gave me cause to have a closer look at my connection stats.
For reference, the entire set-up consists of a phone and the modem/ router (2wire BT1801HG supplied by PlusNet when I joined) plugged into a micro-filter, which is plugged into the main (and only) phone socket. It's a pretty old phone line so it's just a standard socket, not nte5, so no test socket to play with. I don't have another router to test with either.
I took some readings this morning for up-to-date stats. I unplugged the phone so it was just router/ micro-filter/ socket.
After a soft reset, the router stats gave:
dsl line (wire pair): line 1 (inner pair)
protocol: g.dmt annex a
downstream rate: 7776 kbps, upstream rate: 448 kbps
channel: fast
current attenuation: 33.0 dB (down), 17.5 dB (up)
current noise margin: 5.0 dB (down), 23.0 dB (up)
The test at speedtester.bt.com gave:
download speed achieved during test - 382 Kbps
acceptable range of speeds is 400-2000 Kbps
dsl connection rate: 7776 Kbps (down), 448 Kbps (up)
ip profile for your line is - 2000 Kbps
The test was not conclusive and further testing is required.
I tried following the instructions to run the tap 3 test, but it gave an error part of the way through both times I tried. It hasn't always requested this test in the past, but when it has it usually just ends up with an error.
As an extra measure, speedtest.net gave:
download 0.50 Mb/s, upload 0.38 Mb/s, ping 43 ms
After plugging the phone back in to the filter, and soft-resetting the router again, the stats were:
downstream rate: 7808 kbps, upstream rate: 448 kbps
current noise margin: 5.0 dB (down), 22.0 dB (up)
so very similar to without the phone plugged in (not really surprising).
The connection details from the Member Centre show that interleaving is on, estimated line speed is not recorded, and last, but certainly not least, current line speed is 0.5 Mb.
I guess this all leads to a couple of queries. Firstly, is there any reason the PlusNet profile is lower than the BT profile and if not can it be pushed up to match? Secondly is there any chance of getting more speed out of the connection as the downstream rate claims to be nearer the 7 Meg mark. I have noticed the noise margin always seems quite low, and there tend to be a lot of 'DSL loss of margin failures' recorded by the router, which I'm assuming is the main issue.
Any help would be greatly appreciated,
Paul
channel: fast
Paul
Message 1 of 5
(1,169 Views)
4 REPLIES 4
Re: yet another speed question
11-11-2011 10:33 AM
Hi Paul,
I'm going to try resetting the profile and see if we can kick it into life. I'll let you know how I get on.
Jojo
Jojo
Message 2 of 5
(397 Views)
11-11-2011 11:53 AM
Cheers for that.
Stats are looking a bit healthier now:
download speed achieved during test - 1727 Kbps
dsl connection rate: 7808 Kbps (down), 448 Kbps (up)
and it didn't ask me to try running another test this time.
I'll see how the connection holds up over time.
Paul
Paul
Message 3 of 5
(397 Views)
15-11-2011 4:15 PM
Looks like it's upped to 4500 on both our side and BTs, have things improved from your side there at all?
Message 4 of 5
(397 Views)
16-11-2011 11:29 PM
Hi Matt,
Thanks for checking up on me. It's looking a lot better at this end now. Speed jumped up quite quickly after Jojo reset things, then settled down to steady download speeds of around 4MB. IP profile generally showing up as 4000 or 4500 Kbps now.
For reference, latest bt speedtest shows:
download speed: 3142 Kbps
acceptable range: 600-7150 Kbps
IP profile: 4000 Kbps
speedtest.net gives:
download 3.76 Mbps, upload 0.36 Mbps, ping 64 ms
and router is currently showing:
rate: 4768 kbps down, 448 kbps up
channel: interleaved (now agrees with plusnet)
attenuation: 33.0 dB down, 17.5 dB up
noise margin: 14.0 dB down, 23.0 dB up (seeing a lot less margin errors now with higher margin)
Seems fairly stable and miles better than it was before.
Cheers,
Paul
Cheers,
Paul
Message 5 of 5
(397 Views)
