yet another speed query
- yet another speed query
20-11-2007 11:31 AM
Up Speed 448000
Downspeed 6176000
SNR Margin 16.9
Loop Att 31.6
Test data from Plusnet speed test
Date Speed Achieved (kbps)
20-11-2007 11:10:44 434
20-11-2007 11:10:16 726.7
20-11-2007 11:09:52 841.8
19-11-2007 10:13:52 1605.6
19-11-2007 10:13:36 1096.5
18-11-2007 12:14:31 3548.9
18-11-2007 12:14:16 3566.4
14-11-2007 10:58:02 1549.1
From the Plusnet page
Your High-speed Broadband Service
Your current broadband speed is 5000 Kbps
Speed test result
URL=http://www.speedtest.net][/URL]
http://www.speedtest.net/result/204041374.png
Is the slow link due to congestion at the local exchange or what
Thanks for any comments.
About 8 weeks ago I had Openreach in to resolve a line problem, faulty connection at the top of a pole. judging by my line stats I still have a good line.
Re: yet another speed query
20-11-2007 11:38 AM
That's a pretty high SNR margin, but shouldn't be the cause of your problem based on your synchronisation rate.
It's also not profile related, as this is still set to 5000Kbps at both our and BTs end.
Rather than using the oh ever so reliable PN speed test, can you try using http://www.mybroadbandspeed.co.uk instead?
20-11-2007 11:45 AM
Date Download Speed Upload Speed
Today 11:43 1310 kbps (164kB/s) 348 kbps (43.5kB/s)
Today 11:42 2565 kbps (321kB/s) 345 kbps (43.1kB/s)
20-11-2007 11:49 AM
Again, fluctuations could indicate a rather busy exchange.
http://www.plus.net/support/broadband/troubleshooting/rwin_video.shtml
The above link shows you how to tweak your MTU and rWin settings, which again could help to eliminate the problem. I'm afraid in situations like these, it's very much a trial and error process.
20-11-2007 11:55 AM
(no I am not changing platforms <g>)
20-11-2007 12:15 PM
Let me try and find a link that shows how to do it on the Apple.
http://docs.info.apple.com/article.html?artnum=303192
20-11-2007 5:28 PM
Quote from: drw Current stats from the router are
Up Speed 448000
Downspeed 6176000
SNR Margin 16.9
Loop Att 31.6
Speed test result
Hi
Had similar problem was only getting an IP throughput speed of 20 kbps. I raised a ticket about it and the plus net tech boys checked with the BT exchange and agreed there was a fault. they arranged with BT to update, but said I had to leave my broadband modem and connection on for between 48 and 72 hours. I did this but after 20 hours I was informed that the speed was now OK and the throughput had increased to 2752 kbps. The last check showed 5220kbps
20-11-2007 6:38 PM
James
During August this year I was getting very fast connections
This was with an untuned MTU value.
I would have expected that the broadband usage during the day in August would have been greater during the day than now because of the school holidays.
Are domestic users in contention with business users?
Is there a way of determining if the exchange is getting busy (Horndean) and a way of getting BT to increase capacity?
20-11-2007 7:07 PM
20-11-2007 7:21 PM
