yes so my connection is all over the place
- yes so my connection is all over the place
13-10-2013 12:15 PM
since this ive noticed my speeds have gone up so im getting an extra 100kbps approx more on max download speeds. the connection seems unreliable and theres big fluctuations in speed. sometimes mega slow other times its good. the red light bug keeps coming on and going away and earlier my computer said no internet access and i was still surfing and downloading for ages until it cleared.......usually first sign of a drop is page cannot be displayed, so this no access warning on my pc was a first with plusnet yet it was wrong.
can someone please tell me what the hell is going on with my connection ?
Re: yes so my connection is all over the place
13-10-2013 9:44 PM
13-10-2013 10:10 PM
dick:quote
13-10-2013 11:32 PM
14-10-2013 10:45 AM
14-10-2013 11:17 AM
what a load of rubbish!
14-10-2013 11:41 AM
Sorry to hear you didn't get the answer you wanted, is there anything we can help with?
14-10-2013 5:13 PM
bt wholesale speed test
18-10-2013 12:53 PM
i had mixed results from the tests.
18-10-2013 1:44 PM
Threads merged and superfluous posts removed.
18-10-2013 2:15 PM
18-10-2013 3:16 PM
speeds were 45-50% sometimes and them 100% and 90% at some times.
i was told that it would be seen by plusnet what the results were on my account.
18-10-2013 3:36 PM
As for the test results, I did a check for them but couldn't see any I'm afraid, the test option to check results wasn't shown. I'll check again a bit later, though in all honesty we'd need a fault opening for our support team to check those for you and I'm not sure that there is one present - you've not actually described the issues you're having?
19-10-2013 1:07 PM
19-10-2013 3:27 PM
Also, make sure you are doing the test wired rather than wireless - if possible.
