xDSL linestate down, xDSL linestate up...
- Re: xDSL linestate down, xDSL linestate up...
17-02-2014 10:39 AM
I've always had intermittent disconnections on my dsl line. However, sometimes it is much worse - this past weekend has been particularly bad, and it doesn't seem to stay up for more than a few minutes at a time.
Would it be possible for someone to have a peek at my stats to help pin down the issue, please? I would struggle to get through the connection troubleshooter / report a problem form on the website, with the connection as it currently is.
Message 1 of 6
(1,447 Views)
5 REPLIES 5
17-02-2014 10:41 AM
Have you tried connecting via the test socket?
Message 2 of 6
(769 Views)
17-02-2014 10:44 AM
Yes - I didn't notice any improvement. (Also, the phone line doesn't seem to sound noisy).
Message 3 of 6
(769 Views)
17-02-2014 10:52 AM
From what you've said you need to get a fault raised. I'd suggest seeing how far you can get with http://faults.plus.com. It doesn't matter if the connection is up and down while you do it, if you have to go back to it, it should pick up from where you got to.
Message 4 of 6
(769 Views)
17-02-2014 6:03 PM
Thanks! I've reported the fault as you suggest. It does seem to have been slightly better today - I'd be really interested to see a Radius graph in case there is a pattern to it, if at all possible!
Message 5 of 6
(769 Views)
18-02-2014 10:11 AM
Hi bigpig,
I'm just running some checks on your line now. I'll provide any updates on ticket 81413902 with my findings.
Message 6 of 6
(769 Views)
