www.mybroadbandspeed.co.uk Help
paulo
Been using www.mybroadbandspeed as a quick check on my BB speed.  Works fine on my old (usual) PC but now that I am transfering stuff to my new PC mybroadbandspeed refuses to work!!  I suspect it may be an incorrect setting somewhere but cant find whats wrong.    All other activities seem to work normally as far as I can tell.
I'm useing XP pro and IE on both PCs.
Any help would be much appreciated.
Paul.
I can resist everything except temptation.
pierre_pierre
Re: www.mybroadbandspeed.co.uk Help
Java?
Fixes: 9
Have you installed flash yet? http://get.adobe.com/flashplayer/
(It uses flash not Java)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
scootie
is mybroadband speed playing up for any one else right this minute
VileReynard
Seasoned Pro
Fixes: 9
The DNS lookup failed on the PN speed-checker, but worked on a re-try.
It also worked in terms of doing it's speed-checking. Smiley
scootie
working now before it was not letting me run the test and also completly refusing to load the site from a google search
paulo
Quote from: jelv
Thanks Jelv, did not realise that 'flashplayer' was needed for this to run.  Now working great.
Many thanks to all who responded.
Paul
