www.mybroadbandspeed.co.uk Help
- Re: www.mybroadbandspeed.co.uk Help
19-07-2009 9:29 AM
Been using www.mybroadbandspeed as a quick check on my BB speed. Works fine on my old (usual) PC but now that I am transfering stuff to my new PC mybroadbandspeed refuses to work!! I suspect it may be an incorrect setting somewhere but cant find whats wrong. All other activities seem to work normally as far as I can tell.
I'm useing XP pro and IE on both PCs.
Any help would be much appreciated.
Paul.
Paul.
I can resist everything except temptation.
Message 1 of 7
(1,545 Views)
6 REPLIES 6
19-07-2009 10:09 AM
Java?
Message 2 of 7
(698 Views)
19-07-2009 10:32 AM
Have you installed flash yet? http://get.adobe.com/flashplayer/
(It uses flash not Java)
Message 3 of 7
(698 Views)
19-07-2009 3:35 PM
is mybroadband speed playing up for any one else right this minute
Message 4 of 7
(698 Views)
19-07-2009 3:39 PM
The DNS lookup failed on the PN speed-checker, but worked on a re-try.
It also worked in terms of doing it's speed-checking.
Message 5 of 7
(698 Views)
19-07-2009 3:44 PM
working now before it was not letting me run the test and also completly refusing to load the site from a google search
Message 6 of 7
(698 Views)
20-07-2009 9:58 AM
Quote from: jelv Have you installed flash yet? http://get.adobe.com/flashplayer/
Thanks Jelv, did not realise that 'flashplayer' was needed for this to run. Now working great.
Many thanks to all who responded.
Paul
Message 7 of 7
(698 Views)
