www.majorgeeks.com - can anybody access it?
creamola
I have a number of PC's on my home network - none of which can access www.majorgeeks.com.
However, on one of those PC's, I can connect to my companies VPN and the VPN client tunnels ALL traffic across the VPN. The internet pop for the VPN is in San Jose. On this PC, via the VPN to San Jose, I can access majorgeeks without problem - so why can't I access it via Plusnet? It doesn't seem to be a DNS problem because both VPN and non VPN PC's resolve to the same address: 208.101.7.150.
Thanks,
Creamola.
Re: www.majorgeeks.com - can anybody access it?
No problems accessing it here.
You could try rebooting your router which is the only common thing between the PCs.
VileReynard
Seasoned Pro
Fixes: 10
I see it OK - using PlusNet's DNS I get:-
jeremy@HECTOR:~$ nslookup -all www.majorgeeks.com
Set options:
  novc                  nodebug        nod2
  search                recurse
  timeout = 0          retry = 3      port = 53
  querytype = A        class = IN
  srchlist =
Server:        212.159.13.49
Address:        212.159.13.49#53
Non-authoritative answer:
www.majorgeeks.com ;     canonical name = majorgeeks.com.
Address: 208.101.7.150
creamola
weird. I get this:
Server:  ptn-cdns02.plus.net
Address:  212.159.6.10
Aliases:  www.majorgeeks.com
I need to have a look at the router then...
Thanks,
Creamola.
Which is the same.
Jeremy is using is a linux tool not DOS so the output content will differ.
creamola
I know.
Sorry, I meant it was weird that we both get the same results - yet I have no access.
pcoventry76
internal server error here as of 3:21pm
Yip. majorgeeks would seem to be experiencing some difficulty.
Currently returning a 500 error with the default text of
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, webmaster@majorgeeks.com and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
LiamM
Seems to be back now.
