would it be worthwhile starting my training period again
kyle36
would it be worth having my profile reset and interleaving off,router stats below.
thanks in advance
Mode: ADSL_G.dmt.bis
Traffic Type: ATM
Status: Up
Link Power State: L0
  Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (0.1 dB): 65 242
Attenuation (0.1 dB): 500 242
Output Power (0.1 dBm): 186 125
Attainable Rate (Kbps): 5344 888
  Path 0  Path 1
  Downstream Upstream Downstream Upstream
Rate (Kbps): 3068 440 0 0
MSGc (# of bytes in overhead channel message): 93 12 0 0
B (# of bytes in Mux Data Frame): 6 55 0 0
M (# of Mux Data Frames in FEC Data Frame): 1 1 0 0
T (Mux Data Frames over sync bytes): 9 1 0 0
R (# of check bytes in FEC Data Frame): 4 8 0 0
S (ratio of FEC over PMD Data Frame length): 0.718 4.0 0.0 0.0
L (# of bits in PMD Data Frame): 1225 128 0 0
D (interleaver depth): 416 8 0 0
Delay (msec): 7.47 8.0 0.0 0.0
INP (DMT symbol): 5.43 2.0 0.0 0.0
Super Frames: 3805133 3380184 0 0
Super Frame Errors: 31 0 0 0
RS Words: 3390372168 759507 0 0
RS Correctable Errors: 219510 17 0 0
RS Uncorrectable Errors: 929 0 0 0
HEC Errors: 83 0 0 0
OCD Errors: 3 0 0 0
LCD Errors: 3 0 0 0
Total Cells: 440677367 63082791 0 0
Data Cells: 18338845 1189968 0 0
Bit Errors: 0 0 0 0
Total ES: 27 0
Total SES: 0 0
Total UAS: 35 35
  current bt profile 2.5mb
plusnet profile 2.7mb
3 REPLIES 3
Oldjim
Resting Legend
Fixes: 63
Re: would it be worthwhile starting my training period again
If I read your stats correctly we have
Attenuation 50dB
Noise margin 6.5dB
Speed 3068kbps
The answer must be not from that information - BUT
You should try the test socket and report the stats again immediately after connecting as you should be getting better speeds than you are (but wait until it is broad daylight to get the best result) and it just might be that the default noise margin has increased to 9dB and this would show it or not as the case may be.
Your errors seem to be low which is a good sign but may also be down to a higher default noise margin
itsme
What's the purpose of the training period? It's to set the fault thresholds the line is always in training to get the best speed, may take months but the system will get there.
kyle36
thank you both for taking the time to reply, i will try the test socket as you suggested.
regards
kyle36
