wireless web connections
- wireless web connections
17-02-2016 8:11 PM
I'm having wireless problems with my laptop not connecting to web sites. My pc is fine and have speeds of around 38mb web sites load without any problem. My laptop has a simular speed ,but loading web pages takes for ages and then times out .
Would appreciate any help
Roy
Roy
Message 1 of 3
(652 Views)
2 REPLIES 2
Re: wireless web connections
17-02-2016 11:18 PM
hi roy
two questions for you:
Which router are you using?
What are the operating systems on each computer?
you may find an answer here in this topic http://community.plus.net/forum/index.php/topic,148555.0.html on DNS issues.
Best
G
Best
G
Message 2 of 3
(340 Views)
18-02-2016 8:54 AM
Thanks for your reply G
The router I'm using is a Technicolour 582n The main pc is windows 7 and the laptop is windows 10. I have no issues with the PC but the laptop fails to connect to websites and times out most annoying. Thanks for the link yes looks like a DNS problem , not happy they have done this firmware update spent all day yesterday trying to find the problem sorted .They need to sort it as soon as possible.
Message 3 of 3
(340 Views)
