wireless light on TG585v8 is red
IanSn
Don't use wireless much but switched it on today to use with phone.
The connection seems to be working fine but the wireless light is red.
Now confused. Is it supposed to be red?
I thought that meant a connection problem..
Fixes: 16
Re: wireless light on TG585v8 is red
According to the PDF manual for the 585v8, a red wireless LED indicates no wireless encryption at all.
Orange would indicate WEP weak encryption, and green for WPA(2).
IanSn
Yeiks!
Off to sort that out immediately!
Could have sworn I set that...
