wireless error????
- wireless error????
wireless error????
04-09-2007 8:39 PM
hello - me again ummm how do I check my wireless settings and status - I'm not able to send emails and I'm not sure what to do. M x
Message 1 of 3
(1,129 Views)
2 REPLIES 2
Re: wireless error????
04-09-2007 8:47 PM
Are you using your wireless connection to surf at the moment?
Is it just outgoing e-mail that's not working?
Can you receive mail?
If the answer to the above is yes, it's highly unlikely to be your wireless but more like a configuration error with your e-mail.
Make sure that any server settings requiring authentication or user name and password are disabled for your outgoing server (assuming it's relay.plus.net). (I take it you *are* connecting via PlusNet as you can't use the outgoing server from another ISP, you'd have to use theirs).
Which e-mail client are you using?
Have you tried connecting an ethernet cable and disabling the wireless on your PC - can you send mail then?
Message 2 of 3
(306 Views)
04-09-2007 9:38 PM
The OP has another thread running here although it's another topic altogether, it relates to the same problem.
This topic will be locked in favour of the thread already identified to prevent confusion.
Message 3 of 3
(306 Views)
