wireless connection
- wireless connection
wireless connection
06-04-2008 2:28 PM
Hi, Can anyone help, my problem is that i went to the DLINK site to secure my wireless network of which i done sucessfully but now i get a message next to the dlink network icon saying: THE SETTINGS SAVED ON THIS COMPUTER DO NOT MATCH THE REQUIREMENTS OF THE NETWORK- now this may sound silly but i don't know how and where to get to the right place then if i do ,what do i do,i know i'm thick!
Message 1 of 2
(923 Views)
1 REPLY 1
Re: wireless connection
06-04-2008 9:08 PM
if your running vista then go to network and sharing center. then click manage wireless connections and delete the profile for your wireless. then scan for wireless networks like u normaly do. enter your password for your network and choice to save the profile.
i get this alot any changes you make to the wirless sercuirty, ie encpt , passwords then they dont match the saved profile and u have to delete the old profile.
if your on xp then i would think its pretty much the same way.
Message 2 of 2
(196 Views)
