wireless broadband connection problems
- wireless broadband connection problems
07-08-2007 10:54 AM
Could someone help advise me on how to fix my wireless broadband internet connection? I have an ADSL2 router and was happily using the internet for a number of months until something went wrong and the laptop was unable to identify any wireless networks in range. After some tweaking with the laptop I discovered that the wireless switch had been turned off. Once it is switched on the laptop can identify networks in range. When you click on View Wireless networks is states it is connected to H&P which is what I called the network and the strength of the connection is excellent. However, I cannot access the internet.
When you open Network Connections it is connected and again is excellent. The Local Area Connection states it is "not connected". and a network cable unplugged. I have tried to reset the router and access the router by 192.168.1.1 but the quick setup guide for the router does not seem to work either- it states that it cannot find available PVCs and one needs to be set manually. The diagnostics of the router says that the "test authentication with ISP failed" and the "Test the assiged IP address failed". Is the problem that the IP addresses do not match? If so how do I make sure they do? ANy help with this matter is greatly appreciated!
Thank you
Hilary
Re: wireless broadband connection problems
07-08-2007 10:57 AM
This sounds like it's not using the encryption key correctly. Might be worthwhile removing the wireless network from your laptop and setting it up again.
07-08-2007 11:01 AM
My concern would be that the authentication failed message is suggesting that you just have your password entered incorrectly into your router. I haven't seen any connection attempts from you in the last seven days.
07-08-2007 11:12 AM
Re connection attempts in the last 7 days- I've been on holiday!
Chris- I think when I reset the router the security was reset too. So the connection states that it is currently unsecured. How would I check?
Thank you both for your help. I apologise for my lack of IT knowledge!
07-08-2007 11:17 AM
07-08-2007 12:01 PM
07-08-2007 12:04 PM
Basically, your wireless sounds like it's working fine. Your computer is able to connect to the router (the gateway to the internet), but the router isn't connecting to the outside world.
What I think you will need to do is to do a factory reset. there should be a little pin sized hole on the back of your router which you will need to hold down for 15 seconds and then you'll need to setup your router again.
I'll have a quick hunt around and see if I can find any guides.
07-08-2007 12:09 PM
Looking through a few of them they appear to be similar in setup so here goes:-
browse to 192.168.1.20
click Configuration
click Basic Settings
enter your broadband connection details and apply
Other than that I'd have to advise digging out the manual
07-08-2007 12:12 PM
Hilary
07-08-2007 4:25 PM
07-08-2007 4:29 PM
As I mentioned earlier, this is because your computer is connecting to the router, but the router is not connecting to the internet.
To me, it sounds like you need to reconfigure the router as Chris suggested how to earlier. Did you manage to get into the router configuration panel and apply your settings?
07-08-2007 4:37 PM
Chris's suggestion of 192.168.1.20 did not work.
Perhaps I am not doing something correct within the configuration pages. I did not change the IP address it had assigned.
07-08-2007 4:39 PM
You're still not actually connecting to the internet itself. Can you double check the cabling from your router to the phone socket and just make sure no cables have become loose or anything like that?
Also, if you could tell me what the lights on the front of your router are doing, that would be really helpful.
07-08-2007 5:12 PM
Has the complete Internet login "username-based" string been entered on the router? This is (portal) username@<vISP dependent string>, not just the portal username.
07-08-2007 6:12 PM
Re the Internet login "username-based string, I think I know what you mean, ie "username@ISP.com" for example? Yes. Thanks
