wireless Keeps on disconnecting
aldabbagh
I have a Tenchicolor T82n or something like that. The issue is that I keep getting disconnected from wifi. It has happened to our old router (same model). someone please explain the problem?
1 REPLY 1
Pettitto
Fixes: 5
Re: wireless Keeps on disconnecting
Hi aldabbagh,
Have you tried changing your <a href="http://www.plus.net/support/broadband/wireless_broadband/wireless_signal.shtml">Wireless Channel</a>?
