windows 10.....
alvisesouth
windows 10.....
Hello everyone,
as noone has been able to help me yet, I'm starting a new topic.
I'm not having problem about speed or line, In fact all my devices (tablet and phone) work ok. The problem is when I want to use the computers with windows 10. There are 2 in the house and when I try to open a new page I usually get the "impossible to reach" message or it will open with just a lot of text on the left hand side.
I don't have any antivirus or blocking software at the moment
f I do ipconfig /flushdns on the cmd window, most of the times everything seems going better for a while, but after that it won't work well..
I already formatted my computer, and this problem is on both the laptops of the house.
I'm using Ethernet cable, but when i can't open any page i disconnect it and for a minute seems going better, but after that everything get "stacked" ...
someone has a solution for this?
Thank you
Gel
Seasoned Pro
Fixes: 12
Re: windows 10.....
Try amending your dns settings on your router to google's;
ie
8.8.8.8
8.8.4.4
If you're using a PN Hub One router you can't amend dns settings centrally, so would have to do on each connected pc.
Does it help?
matthewa
Re: windows 10.....
Many thanks for that. I've also just been having exactly this problem and changing DNS servers seems to have fixed it - any idea what the problem is with using the PlusNet DNS servers with Windows 10?
Gel
Seasoned Pro
Fixes: 12
Re: windows 10.....
matthewa
Re: windows 10.....
Investigating a little further: seems to be related to the Technicolor TG582n IP spoofing discussed elsewhere (eg. https://community.plus.net/t5/Fibre-Broadband/DNS-Issues/m-p/1293624#M32060). Either setting WANDownSpoofing=disabled in the router or bypassing the router DNS altogether seems to fix the problem (for me anyway - I have regular ADSL broadband by the way). Problem seems to have got worse with the Windows 10 Anniversary Edition update, maybe they have changed the DNS caching behaviour.
