will my router work with fibre?
- will my router work with fibre?
28-08-2011 3:33 PM
i currently use for my ADSL the netgear DGN 2000
willi be able to use this with the fibre broadband?
Message 1 of 8
(1,432 Views)
7 REPLIES 7
Re: will my router work with fibre?
28-08-2011 3:58 PM
I am afraid not :(. You will need to get a cable router for fibre.
Message 2 of 8
(639 Views)
28-08-2011 6:41 PM
thanks
is the one they supply any good?
will any cable router work?
cheers
cheers
Message 3 of 8
(639 Views)
28-08-2011 7:21 PM
Yes
probably yes as long as it supports PPPoE and has a WAN port > 10Mbs
Message 4 of 8
(639 Views)
29-08-2011 7:19 AM
is the router they provide any good?
Message 5 of 8
(639 Views)
29-08-2011 9:32 AM
My first yes was the answer to that question.
Message 6 of 8
(639 Views)
29-08-2011 11:48 PM
ah ok.
thanks
thanks
Message 7 of 8
(639 Views)
30-08-2011 12:05 PM
Hi cyclopops,
For your information, the router we supply is with our FTTC product is the Netgear WNR1000v3 router and we've had good feedback on the whole from our customers.
Hope that helps.
Hope that helps.
Message 8 of 8
(639 Views)
