wifi problem
- Re: wifi problem
wifi problem
22-07-2015 9:31 PM
I have a brilliant connection downstairs on laptop..iphone and ipad ...but as soon as I go upstairs my ipad wont connect...but the laptop and iphone do !!! can anyone help
Message 1 of 3
(629 Views)
2 REPLIES 2
Re: wifi problem
22-07-2015 10:42 PM
Hi Peter,
A warm welcome to the forums. Ipads seem to be rather sensitive to wifi variances. Though I have good reception throughout my house, there is just one point where the iPad has quite variable performance. Turning it 90 degrees can take it off the network.
You could try turning your router through 90 degrees and see if that helps. Otherwise it will be a matter of looking at a change to or additional technology.
Kevin
Kevin
Message 2 of 3
(333 Views)
Re: wifi problem
22-07-2015 10:55 PM
You could try experimenting with different wireless channels but given the nature of the problem being the ipad itself, it may require you to have a wireless extender so that the signal is even stronger upstairs and hopefully satisfy the Ipad that way but unfortunately neither of the above can truly guarantee it will do the job, guess it depends how much fond you are of the Ipad as to what the best action is to take.
Message 3 of 3
(333 Views)
