wifi issues SE4 postcode
natali31
HI,
I am having issues all morning, the wifi keeps going and coming back. Please can someone help?
Gel
Seasoned Pro
Fixes: 14
Re: wifi issues SE4 postcode
You may need to alter your wifi channel in the router; d/load the programme SSIDinsider; it'll show you what wifi channels in
use in vicinity of your router; change yours to one with no or least use.
Fixes: 205
Welcome to the community forums @natali31
Do you experience the same issues on both wifi and a wired connection? If it's only happening on wifi and not also on a wired connection, the advice given by Gel is probably the best way forward.
 Harry Beesley
