why slow upload speed?
- why slow upload speed?
- « Previous
- Next »
Re: why slow upload speed?
13-12-2013 3:41 PM
I'm not sure what you're asking really? The stats show that you are syncing at 1152 upload.
Message 31 of 39
(396 Views)
13-12-2013 3:57 PM
I'm asking is their anything els you can do to get my upload speed higher, looking at my router stats?
Message 32 of 39
(396 Views)
13-12-2013 3:59 PM
Quote from: Oldjim That is probably as good as you are going to get
Jim's already said that it's pretty unlikely to get any significant improvements.
Message 33 of 39
(396 Views)
13-12-2013 4:19 PM
If my router is syncing at 1,190 what does that mean?
Message 34 of 39
(396 Views)
13-12-2013 4:36 PM
The sync is the connection speed between your router and the exchange. The speed you get in speedtests will always be under this due to the very nature of ADSL.
Message 35 of 39
(396 Views)
13-12-2013 4:49 PM
Ok thanks. So their is absolutely nothing els at all you can do to get my upload speed any higher?
Message 36 of 39
(396 Views)
13-12-2013 5:28 PM
Upgrading to fibre would be the only way it'd improve, I'm assuming either it's not available for you or you haven't requested an upgrade to that though. You can find out if it's available by putting your phone number into http://dslchecker.bt.com/
Message 37 of 39
(396 Views)
13-12-2013 5:30 PM
You can ask for an upgrade to Annex M which should give a better upload speed, you may lose a bit on the download though, but that's pretty good on your short line. There will be a cost for this, not sure of the amount.
Message 38 of 39
(396 Views)
13-12-2013 6:44 PM
£12 per month
Message 39 of 39
(396 Views)
- « Previous
- Next »
