why is my speed capped?
- why is my speed capped?
15-01-2014 3:29 PM
can anyone tell me why my connection is capped ?
i never sync below or above (Up/Down) [kbps/kbps]: 899 / 4,544
Message 1 of 5
(708 Views)
4 REPLIES 4
Re: why is my speed capped?
15-01-2014 3:45 PM
possibly a long line, can you paste some router details?
Message 2 of 5
(447 Views)
15-01-2014 3:47 PM
Not sure about the upstream, but the downstream is banded between 2Mb and 4Mb - happy to do an SNR reset if you wish? I should say though that the copper line test failed which might indicate a fault on the phone line. Don't worry if you've not noticed anything though, but if you have it'd be worth getting it resolved before resetting as otherwise you won't get the best speed your line is capable of.
Message 3 of 5
(447 Views)
15-01-2014 3:52 PM
i aint noticed anythink mate so you can go ahead and do a reset please
Message 4 of 5
(447 Views)
15-01-2014 4:01 PM
Excellent, thanks - reset submitted, should be around 4 hours or so (hopefully less) for it to kick in.
Message 5 of 5
(447 Views)
