why do i get .5mb top speed????????
superdee84
i have just paid my second bill with plus net and found it okey so far until my gaming started lagging. i have done severallllll speed test and at max i get 0.5mb,  most of the time its only 0.2/0.3mb any one help!!!!!  when i first signed up it estimated my speed as 3.0mb (1.5mb min) but im not even getting half of that i have tryed all suggested methods ie: new new bt master socket,moved comp so nothing is near my router new cat5 cables etc, etc any one any ideas.....TY.....
Re: why do i get .5mb top speed????????
What are your router stats? See http://www.kitz.co.uk/adsl/frogstats.php
Post the results of a BT speedtest which will show your sync rate and IP profile: http://speedtester.bt.com
What is your plusnet IP profile set to: https://portal.plus.net/my.html?action=data_transfer_speed
superdee84
Download speed achieved during the test was - 423 Kbps
For your connection, the acceptable range of speeds  is 50-500 Kbps.
Additional Information:
Your DSL Connection Rate :800 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 500 Kbps
thats one of the best results...
Telephone number:
Phone exchange:
KILMARNOCK
Estimated line speed:
0.5Mb (This may System Date and Time
vary between 1Mb and 4Mb) - Checked on 2011-02-12 14:14:37
Current line speed:
0.5 Mb
 LAN Settings
Date/Time February 21 2011 , 21 : 27 : 35   LAN MAC Address                       IP Address                             192.168.2.1
Version Info   Subnet Mask                          255.255.255.0
Runtime Code version  F5D7633-4Av1_UK_1.00.000  DHCP Server                          Enabled
Boot Code Version 1.0.37-5.15
Hardware Version  V1.0J3  WLAN Settings
ADSL Modem Code Version  A2pB015c6  Wireless Function Enabled
Serial Num 168-168-16888  WLAN MAC Address    Mode
125 High-Speed Mode
Features   SSID belkin54g
Firewall Enabled   ESSID Broadcast Enabled
NAT Enabled   Channel 11
UPnP  Disabled   Security WPA-PSK
ADSL   Internet Settings
Type Interleave   Default Gateway 195.166.128.243
Status No Defect   Primary DNS Server 212.159.6.9
Downstream     Upstream
 Secondary DNS Server 212.159.6.9
Data rate 800  448
in 8.6  18.0
 LAN IP Address
Output power 15.4  12.3
 Default Gateway
Attenuation 63.0  31.5
 Primary DNS Server
This is a public forum.... remove your phone number!
superdee84
soz New to forums
[Moderator's note by Jim (Oldjim)  and we don't like shouting either - all caps removed ]
Fixes: 61
It would appear that you are just miles from the exchange and your speeds are about right
Also remove your WAN IP address.
You are on a very long line (63dB line attenuation) so the chances of getting a faster connection are little to none. Your 800Kbs sync rate limits your data rate to 0.5Mbs hence your slow speed (the 1Mb to 4Mb speeds are an estimate and not a guarantee your speed will be between the figures quoted).
Are you connected to the master socket. If not, try that again and post the router stats again as they may improve, although probably not by much. Note the only bts of nfo we need are line attenuation SNR/Noise margin and sync rates for both upstream and downstream.
Have you also tried connecting to the test socket which is behind the lower removable part of the master socket. This will eliminate any local phone wiring which may be interfering with the signal.
I assume you have ADSL filters on all phones, modems, faxes and sky boxes?
superdee84
i have replaced the master socket as the other one was old . i only have the one socket and theres a filter in this. i did have bt before and got a speed of 2.0ish mb my exange is in my town approx 2.5 milesaway
jojopillo
Hi superdee84,
Have you a test socket you can plug into?
Jojo Smiley
superdee84
thanks to all that replied problem is now fixed nothing to do with plusnet it was a bt fault and bt have repaird that fault now guess i am not too far away from the exange after all lol
jojopillo
Hi superdee84,
Your profile looks good but your speed isn't very good. Your line is still dropping quite a bit so I wouldn't be surprised to see the profile go down again. Have a look here for some tips.
Jojo Smiley
