which router
- which router
which router
25-11-2012 5:53 PM
I need to replace my old router a D-Link DSL2740B can not cope with skype and the wireless struggles even though it's a small house, it keeps dropping out, but Ive had it many years so can't complain, would the one Plusnet use now be ok or what would you suggest? house has four students if that is a consideration.
thanks dabba
thanks dabba
Message 1 of 4
(766 Views)
3 REPLIES 3
Re: which router
25-11-2012 8:32 PM
I'd say the current 'Technicolor' TG582N router issued by Plusnet is resoundingly okay. Some people get along fine with it but a minority run into difficulties, for example as per http://community.plus.net/forum/index.php/topic,108698.0.html
Give my regards to Yabba & Doo.
Message 2 of 4
(357 Views)
Re: which router
26-11-2012 11:09 AM
many thanks, just looked at the link and maybe not the best choice?
dabba
dabba
Message 3 of 4
(357 Views)
Re: which router
26-11-2012 11:14 AM
Asus N66U
Or
Netgear N900
I'm going to get the Asus as its cheaper and won router of the year and user reviews on amazon are stunning .
Or
Netgear N900
Message 4 of 4
(357 Views)
